Laser Scanning
Laser Scanning
Post by simso » Sun Oct 13, 2013 2:14 pm
Ive been asked a few times regarding laser scanning, where to buy from, what do I need and how much do they cost.
Whats involved in scanning in an image, can the image be then punched out on a cnc router and so forth.
So Im just going to give a brief tutorial and explanation on how they work, from this you can work out if its for you
Ill scan a guitar in and show the process involved
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 2:15 pm
So starting with a hamer guitar
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 2:28 pm
Laser scanners come in all forms / shapes and size. Cost is reflective to accuracy required.
The other side issue is the more accurate you want the scan the less depth of scan can be achieved.
Example if you wanted to scan a building in, then the accuracy would be about 20ft, and depth of scan is probably 100ft
My laser has a depth of field scan of 40mm, beyond 40mm it cannot see it, the accuracy however is 0.005", which is totally unneccassary for woodwork, however I do on occassion scan aircraft parts in for a local business
Laser scanner.jpg (59.53 KiB) Viewed 16377 times
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 2:31 pm
You need to mount your laser scanner to a machine, for accuracy we retrofitted a cnc router table to hold the scanner head
You could set it up to flat scan or rotary scan, this is all subject to you the end user
Fitted to a cnc router table.JPG (159.54 KiB) Viewed 16376 times
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 2:32 pm
You also need a computer to capture the images from the laser and control the machine holding the laser head
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 3:06 pm
In this image, the laser is sitting over the top of the body on the edge, each of the two inbuilt cameras gives a 45 degree resultant image, as shown top and bottom
You can see the guitar is about 50mm, but the laser and cameras only show half the body depth, this is because I focused the top of the job as the centre point of my image on the screen. This means I have 20mm of focus above the job and 20mm of focus below the job
in scan.JPG (159.2 KiB) Viewed 16370 times
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 3:09 pm
You set depending on how deep the resolution, the amount of passess and overlaps to achieve the end result, each pass is recorded as strip data as shown here
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 3:12 pm
At the end of all scanning, you select - stitch, which collates all the individual scan paths, it uses a small amount of overlap from each scan to realign all the strips
This gives you a 3d view of one side of the guitar
one side hamer.JPG (119.66 KiB) Viewed 16370 times
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 3:15 pm
From the single sided scanned image, you output the file into something you can edit for reverse machining, example an stl file, this stl file you then have to bring into whatever software your using for your cnc router, for me its cut3d, or you could use aspire or cad or solidworks or rhino, the list is endless
demonx
Re: Laser Scanning
Post by demonx » Sun Oct 13, 2013 3:55 pm
Great post.
Hope you realize you just added another thing to my wish list!
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 4:26 pm
In the cnc editing program, you import the scanned image in, to then start drawing up
cnc program.JPG (47.61 KiB) Viewed 16359 times
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 4:29 pm
Is it worth it, IMO no, is it handy - hell yes...
I went down this path many years back because I contracted some local shops that did 3d scanning to scan some jobs for me, they charged $450 a scan and took approx 6 days to turn the job around.
At that time, I thought it was a ridiculous price, and decided to set myself up, I started with no knowledge of scanning, many dollars later we were setup, but in hind sight 450 a scan was not too bad.
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 4:59 pm
Last but not least, I dont actually end up using the 3d model for all my machining, but I use it as a reference to create vectors for my cnc machine. These vectors I can then tell the machine how deep and how wide I want the cuts at these points, the vectors can also be used for the laser cutter to make an mdf template if you wish to hadn route it out with
And that, is this finished, it can also be done for the opposite side, should you wish
hamer vectorised.JPG (69.87 KiB) Viewed 16353 times
Re: Laser Scanning
Post by kiwigeo » Sun Oct 13, 2013 7:15 pm
Thats not a laser...THIS is a laser!!
Re: Laser Scanning
Post by simso » Sun Oct 13, 2013 10:37 pm
That's a scary looking laser
Re: Laser Scanning
Post by Kim » Thu Oct 17, 2013 9:24 pm
Thanks for posting this Steve. 8)
Not something I'm in a hurry to spend on right now however its really good to get an insight into the process and possibilities. Whilst that level of tech tooling may not be viable for me, I can certainly understand the reasoning behind the investment in a commercial operation such as yours.
Re: Laser Scanning
Post by simso » Thu Oct 17, 2013 9:35 pm
Thanks Kim,
As I said if I knew, what I know now, about laser scanning and associated costs I wouldn't even think of doing it.
I will never recoup my costs, but in a repair business it is an exceptional tool to have, we can match pick guards bodies necks etc perfectly
I've seen laser scanners as cheap as a couple of k, and there okay but the accuracy is more in cm than mm,
Users browsing this forum: No registered users and 99 guests
