How to bury ferrules? ...or is that ferals?
slowlearner
Post by slowlearner » Mon Dec 02, 2013 11:57 am
Having put off using them for so long, I gave in and finally went looking for some ferrules (not to be confused with 'ferals').
http://www.ebay.com.au/itm/400397064098 ... 1439.l2649
When they arrived (in a record 6 days!) I then started trying to figure out how to put them in. They're 14.2mm in dia, to be precise. Initially I thought drill a 14mm hole in a router guide and using a pattern bit to make the recess would do the trick, but it was so tight, I had to hammer the ferrule in. If you look on the left at the pic below you can see what I had to do to get the ferrule out of the test piece... :oops:
Then I went looking for a 14mm router bit, but of course the local hardware doesn't have that. They have 12.5 and 16, but that's it. In my seaching I came across a 15mm forstner bit. You can see the ferrule has some space around it. This is what I'm concerned about.
What I'm thinking is that space is ok, coz once I oil the body, I'll have a smaller hole and the ferrule should be snug, without being ridiculously tight like before. If this right approach or do I need to start again?
Pete
Re: How to bury ferrules? ...or is that ferals?
Post by jeffhigh » Mon Dec 02, 2013 1:22 pm
You will need a 9/16" brad point drill
Try Ebay you won't get it from your local hardware
Post by kiwigeo » Mon Dec 02, 2013 8:02 pm
For ferals...come to the Adelaide Hills.
slowlearner
Post by slowlearner » Mon Dec 02, 2013 10:20 pm
jeffhigh wrote:You will need a 9/16" brad point drill
I found one on ebay...
http://www.ebay.com.au/itm/9-16-5-8-3-4 ... e91&_uhb=1
Price + shipping = :cry:
I think I'll stick with the 15mm for now. :roll:
Pete
demonx
Post by demonx » Wed Dec 04, 2013 7:28 am
I use forstner bits for any work like this, control knob recessed, I also use forstner bits (saw tooth) output jack holes.
I no longer let a spade bit anywhere near a guitar and the only time I use a brad bit is tuner, switch and pot holes.
When I discovered forstner bits a few years ago it changed my life! Only problem is they blunten too fast hence why I've swapped over to saw tooth forstner bits.
slowlearner
Post by slowlearner » Sat Dec 07, 2013 1:50 pm
Do you have a supplier for them?
Pete
slowlearner
Post by slowlearner » Tue Dec 10, 2013 4:37 pm
cheers :)
Pete
Users browsing this forum: No registered users and 123 guests
