Advice on neck repair
Pappy Green
Post by Pappy Green » Fri Dec 06, 2013 10:44 am
Hi all,
wondering if I can get some advice. I have been asked to repair a banjo neck that was damaged on a flight. It looks pretty clean (haven't seen it up close). Are there any specific tips from the greater font of wisdom?
thanks
banjo break.jpg (62.21 KiB) Viewed 13743 times
Kev3
Re: Advice on neck repair
Post by Kev3 » Fri Dec 06, 2013 11:12 am
Never tried a repair on this type of thing, but it looks like a pretty clean separation of the finger joint from that picture. - More like the glue failed with minor breakage of the timber at the extremes of the "fingers"
Kevin
Post by rocket » Fri Dec 06, 2013 11:28 am
A finger jointed neck? Now I've seen it all
Kev3
Post by Kev3 » Fri Dec 06, 2013 2:04 pm
Yep, pretty sure its some sort of finger joint - check out this pic
Kevin
Post by jeffhigh » Fri Dec 06, 2013 2:44 pm
Pretty common on the low end Taylors
demonx
Post by demonx » Fri Dec 06, 2013 3:22 pm
If it ends out that the joint is un repairable, the way many broken headstocks are repaired is to cut a scarf joint and simply make a new headstock. Not as simple as a glue up, but a backup plan to keep in mind
Post by kiwigeo » Fri Dec 06, 2013 3:50 pm
"Goodtime"......... :lol:
Post by simso » Fri Dec 06, 2013 8:57 pm
Yeh deerings and all that use it all the time,
the thought is to maximise the contact area during glue up, usually there pretty good, they only fail at the joint if insufficient glue was used,
Just glue it up and it should be perfectly fine, (make sure old glue is removed)
tippie53
Post by tippie53 » Sat Dec 07, 2013 1:44 am
use a glue remover like deglue or make one up with KY jelly and white vinegar . Then you can try reglueing it. I may opt here for epoxy or med ca and let clamped for 24 hr.
Member of the board ASIA
Bruce McC
Post by Bruce McC » Sat Dec 07, 2013 10:23 am
That would really make your eyes water if you got that mixed up with your personal lubricant :shock: :shock: :shock: :shock: :shock:
Bruce Mc.
Post by simso » Sat Dec 07, 2013 11:20 am
tippie53 wrote:use a glue remover like deglue or make one up with KY jelly and white vinegar
Today was a good day, I learnt something new again. I have never tried that recipe, but you bet I will on monday.
Thanks for the tip John
Post by kiwigeo » Sat Dec 07, 2013 1:04 pm
LOL.......I'm picturing a few members trying to explain to their wives why the KY jelly stocks are running low :mrgreen:
Pappy Green
Post by Pappy Green » Sun Dec 08, 2013 9:54 pm
I am much obliged to you all for the advice. :D
