Stewmac sheilding paint drying time in hot weather?
- slowlearner
Near on 100degF here in Western Sydney today (37degC). Put the first coat of shielding paint on. It's water based. Surely in this heat I don't have to wait 24hrs (like the can says) to recoat?
Pete
Re: Stewmac sheilding paint drying time in hot weather?
I don't usually adhere to their guidelines anyway Pete, once the coat has dried to an even dull grey I'll rub a finger over it. If I can feel a smooth surface and my finger doesn't 'drag' or clag up in any way and my fingertip has a fine graphite powder on it as opposed to a lumpy coating, it should be good to go for another coat. I don't time it but I'd say I usually find I can recoat anytime after 12 hours. I think Stewmac's 24hr recommendation is probably a bum covering exercise to stop people blaming them and their product for a poor application because the previous coat wasn't properly dry and a second coat pulled or dragged at the first coat. 24 hours would be a safe blanket time to cover most climates and people's differing shop conditions I would say.
If your shop is at 37 I'm surprised it's staying wet long enough for you to brush it on!
- slowlearner
Was a bit like that actually. Bass is together now, just waiting on a few wiring joints and good to go!
Pete
38 degrees in my workshop today.....had to stop work after puddles of sweat started pooling on the engleman top I was working on.
45 degrees in Geelong today.
Got into the workshop about 8.30 and lasted until 11.
Had to go for fluid replacement therapy - Heineken.
- needsmorecowbel
Got to a max of 30.5 degrees, 44% min rh in my shop at the end of the heat wave...seems like double insulation is workin
Tis definitely beer worthy weather
Stu
Stu
shifted into the office where i have a small aircon - lucky i had a few setups to do
the workshop here [near the dandenongs melb] got to 37 on the the hottest days so really just out of working range
i generally knock off after 35 and move to cooler areas
In front of the fridge with a cold one?old_picker wrote:i generally knock off after 35 and move to cooler areas
Pussies the lot of ya...
Users browsing this forum: No registered users and 129 guests
