A dread for Jack
nnickusa
A dread for Jack
Post by nnickusa » Fri Jan 31, 2014 3:08 pm
Got asked to make a dread for this young fella's 18th, and was only 2 months late, but they are understanding, and know all the BS I was going through for a while, so it's all good.
Top: AAA Sitka
B/S: Mango
Neck: Qld Maple. Mulga top plate, Mango back plate.
Binding/Fretboard: Mulga
Bridge: Mulga/Maple/Mulga
Purfling/Rosette: Red Celluloid, B&W Plastic
Electrics: Fishman Matrix Ellipse
Tuners: Grover Sta-tites
Finish: Mirotone 3220
Better sprayed finish that last time, but still a bit or room for improvement, overall, certainly my best yet.....
Hope you like.
Bridge pins will be replaced with bone when it comes back after a play in period(just don't have them on hand)
GregL
Re: A dread for Jack
Post by GregL » Fri Jan 31, 2014 3:57 pm
Hi Nick,
Wow, that looks great! Good job!
GregL.
Tod Gilding
Post by Tod Gilding » Fri Jan 31, 2014 5:58 pm
That looks great Nick, I like the laminated bridge . I have done something similar on my current build.
steve roberts
Post by steve roberts » Sat Feb 01, 2014 9:01 am
Hi Nick
Great job looks briliant
Regards Steve
nnickusa
Post by nnickusa » Sat Feb 01, 2014 9:18 am
Thanks guys.
Tod, the bridge ended up like this as a result of a brain fart. I cut the bridge blank up for the head plate instead of the fretboard tail, as I thought. Sooooooo, I had a wafer of Maple, and went with that. The maple is also why i want the bone pins now. I think it'll tie in better.....
Tod Gilding
Post by Tod Gilding » Sat Feb 01, 2014 9:31 am
No No ...not a Brain Fart ...Artistic Luthier Magic is what it is called :D
Shane Woonton
Post by Shane Woonton » Sat Feb 01, 2014 1:49 pm
Nice work Nick! I like the celluloid. Did you put anything underneath it? And how did you go keeping it flat while bending it for the purfling?
Shane
nnickusa
Post by nnickusa » Sat Feb 01, 2014 2:23 pm
Cheers, Shane.
Ah. The celluloid. 1.5mm x2mm of bending on the flat. If I never domit again, it'll still be too soon. I traced the outline of the top on my bench, and, using pan head stitch screws every 10-15mm, help it down flat. I pinched the missus's hair dryer to heat it up for the bending, and it helped a lot. Still a real bitch, but I do like it. That's why I used the blue celluloid on the tele I finished.
