So I designed this truss rod to pull it back down...It's made from a length of M5 threaded rod with a nut and washer....It worked great
That took a bit of thought....First thing I did was make a hardwood block with a 6mm hole drilled at an angle ..I glued that to the underside of the fingerboard...I made up a long 4mm drill bit by grinding the end of a spare length of M5 threaded bar ..I then inserted it through the 6mm hole and then I used it to bore a 4mm hole 1" deep into the heel of the neck..I then screwed the end of M5 truss rod hard into the 4mm hole with a drop of CA glue to hold it in placesimso wrote:How have you anchored the other end
It's a common enough problem. Also, the sound post is usually more to the centre of the bass than even close to the G foot of the bridge. The fb in the photo was replaced. This one has almost 5mm of relief, if I removed the hump around the 4th fret it would be worse.Allen wrote:That's a very clever fix you worked out there Ken. The Chinese factory should just install those as part of the "deluxe" fit out.
The factory should simply install a decent fingerboard on the "deluxe" model, IMO.Allen wrote:That's a very clever fix you worked out there Ken. The Chinese factory should just install those as part of the "deluxe" fit out.
Try "Is You Is Or Is You Ain't My Baby", Tom & Jerry versiontimbuck wrote:Now can any one direct me to some good bass parts to learn to play co's the family is fed up with "These boots are made for walking" and "Fever".
There is no danger the fingerboard will come off ..the small block glued underside with Titebond will come away before that...The wood is maple no lacquer just stain...and the pressure on the nut to pull the end down is just slight, almost finger tight..it's not like a guitar trussrod pulling end to end....Trust me I know whats whatmatthew wrote:The factory should simply install a decent fingerboard on the "deluxe" model, IMO.Allen wrote:That's a very clever fix you worked out there Ken. The Chinese factory should just install those as part of the "deluxe" fit out.
I may be completely wrong but i don't think that ingenious fix will last very long. I think it will simply pull the top of the fingerboard forwards, either off completely, or bend the neck, increasing the bend at the "money" end, which is worse. Unfortunately the necks on those basses are usually lacquered heavily to hide the often spalted and d grade wood used. and thats where they give way at the slightest knock.
ok. I guess it's just a big ukulele after all.timbuck wrote:.Trust me I know whats what
matthew wrote:ok. I guess it's just a big ukulele after all.timbuck wrote:.Trust me I know whats what
