- IMG_1726.JPG (174.69 KiB) Viewed 23395 times
colburge wrote:demonx wrote:All the instructions I've read and videos have said 320F and bake at 260f !!! Are we using the same bender & controller?
I am using an LMI blanket and the same controller as you. I just bent some uke sides at around 80 thou thick, with a tighter radius then you, and started winding down the waste at 120F and finished when it was at 210F, no problem. i read the same recommendations as you, and it just burnt the wood. I have practiced on lots of different woods with the same results, the only one I can't get to bend, no matter what is qld maple.
Col
i don't know if i have more ass than class but i use a home made bender, a LMI blanket no controller, turn it on for a minute or so, turn off for a while and back on , just go by feeling how hot it is, don't rush to bend the stuff, let the heat penetrate the timber . and bend gradually, this is the most sophisticated method i've used so far, before this i've used, hot pipe, heat gun,halogen globes to heat bender, i find the silicone blanket the best heating method so far, bent blackwood,purple heart,Qld maple, curly maple, no problem, i just spray a little tap water on the sides wrap in brown paper then alfoil then whack it in the elcheapo home made bender.
Must be more ass than class i think!!
Cheers,,
