Bridge Rotation...Another approach
Post by woodrat » Fri Aug 22, 2014 7:50 am
I am sure that I am not the only one who has thought of this.....but I thought that I would post the rig I knocked up very quickly in the workshop. It is just a background scale and then a long pointer to read the scale against attached to the guitar top with a couple of my trusty workshop helpers...AKA bamboo skewers...:)
Anyway to get the one degree graduations it is helpful to know that 1 deg is 1 in 57.29 slope. So I drew a 573mm long line and then stepped out 10 mm for every 1 deg to get my 5 degree each way scale.
My test mule was my first guitar I ever bought, a Washburn M.I.C. Dred with a solid top....I wanted to know this because I plan to sand the braces away until I get 2 deg of bridge rotation and then see how the old box sounds....:)
So I did the test setting it up on 0 deg and then dumped the string tension holding the guitar very steady on the solid neck support I have to make sure that the guitar didn't move at all.
The result for the Washburn was that there was about 0.66 or 2/3rds of a degree of rotation. I tested one of my latest and found about 1.25 or 1 and a 1/4 degrees so I am still overbuilding somewhat....
Here are the photos...sorry for the bad photography but it was done in a bit of a hurry....
I hope this has been helpful ...
weslewis
Re: Bridge Rotation...Another approach
Post by weslewis » Sat Aug 23, 2014 1:24 pm
I use a cad drawn scale , pointer attached to a aligator clip and a cheap dial indicator holder from harbor freight :gui :dru
2012 11 15_0368 (2012_11_16 04_02_18 UTC).JPG (141.29 KiB) Viewed 8332 times
2012 11 15_0369 (2012_11_16 04_02_18 UTC).JPG (177.86 KiB) Viewed 8332 times
2012 11 15_0370 (2012_11_16 04_02_18 UTC).JPG (175.78 KiB) Viewed 8332 times
2012 11 15_0371 (2012_11_16 04_02_18 UTC).JPG (164.33 KiB) Viewed 8332 times
Post by woodrat » Sat Aug 23, 2014 2:35 pm
Wes that's certainly cooler than mine....and great photography too....thanks for posting
...I find this an easier approach because I find measuring the the two numbers to punch into the formula quite difficult....
...I have always wanted a dial indicator stand ( I have a dial indicator for top thicknessing) so I think I will get one now....
WR
Post by jeffhigh » Sat Aug 23, 2014 6:51 pm
I would not be deciding whether a guitar is overbuilt purely on bridge rotation. Achieving target top frequency is a more important goal.
Your washburn may however be overbuilt, For the same overall stiffness, X braces are going to tend to give more rotation due to the flexibility of the bridge area compared to a falcate with bracing directly under the bridge.
Post by woodrat » Sat Aug 23, 2014 9:40 pm
Thanks Jeff.....I do try to get my resonances where I want them first....I have only recently been paying more attention to bridge rotation....your point is valid...Thanks for reminding me :)
WR
