12 string bridge
maurie
12 string bridge
Post by maurie » Wed Sep 24, 2014 11:56 am
I am currently building a 12 string dreadnought and about to drill the bridge for bridge pins.
I have noticed that some manufacturers locate the octave strings differently.
Martin and others locate the main strings further from the saddle with octaves closest. Gretch, Fender and others position main strings near to saddle with octaves at the rear.
I am tempted to go with the mains closest to the saddle.
My reasoning is, Better break angle on the main strings over the saddle, better string clearance where rear strings pass the front bridge pins and possibly less torsional lift on the bridge.
The only reason I can think of for having the octaves closest to the saddle is it may limit sideways string movement on the saddle for a hard player.
Any thoughts???
Maurie
Re: 12 string bridge
Post by kiwigeo » Wed Sep 24, 2014 12:05 pm
Maurie,
Before you go any further read this thread: viewtopic.php?f=5&t=354
Also do a search on any of Craig's other threads on 12 strings. I built a 12 banger a few years back and there will be a thread or two in which compensation and bridge pin options were discussed.
Cheers Martin
maurie
Post by maurie » Wed Sep 24, 2014 12:19 pm
Thanks for that Martin and a great tute from Craig.
If the client agrees, that will be the way I go
Cheers Maurie
ckngumbo
Post by ckngumbo » Thu Sep 25, 2014 10:08 am
What a great thread! Thanks to all concerned.
Post by Kim » Thu Sep 25, 2014 10:47 am
For this mark-out in particular, and in fact every other mark-out undertaken when working with un-weldable woods, I highly recommend adding a KUM (no smart arse comments thanks), 2 stage, long point, pencil sharpener to your kit....
Bought my 3 from this bloke, cheapest with post I've found and had no hassles at all.
http://stores.ebay.com.au/Fast-Penguins ... d=89023569
Post by kiwigeo » Thu Sep 25, 2014 10:58 am
Who thinks up the names for some of these products?
Post by charangohabsburg » Thu Sep 25, 2014 11:21 am
kiwigeo wrote:Who thinks up the names for some of these products?
The German, obviously.
No surprise because they have a non-glorious, 1000 year long tradition for overly long and complicated descriptive names. :(
Post by kiwigeo » Thu Sep 25, 2014 11:24 am
There's a little shop in Sapporo Japan called "The Clap Wedding Agency"....
ozwood
Post by ozwood » Thu Sep 25, 2014 5:28 pm
We Make a Compost Probe, it was developed for Australian Native Landscapes. They called it the ANL Probe , it's two meters long 40 mm round , pointy with a handle on the end.
And due to where they stick it , it often smells a bit like poo !
Paul .
Post by kiwigeo » Thu Sep 25, 2014 5:40 pm
My poor Niece got the initials ARS
Post by Craig » Fri Sep 26, 2014 7:45 am
Kim wrote:For this mark-out in particular, and in fact every other mark-out undertaken when working with un-weldable woods, I highly recommend adding a KUM (no smart arse comments thanks), 2 stage, long point, pencil sharpener to your kit....
These look to be just the thing thanks Kim . I'll be giving them a go for sure . I previously fluked some fairly good sharpeners from our newsagents . Fairly cheap ones but they sharpen to that looong point , and I'm able to unscrew the blades and resharpen them ( but once only).
B.T.W. I've now had that 6 pinner bridge in use for around 7 years without any problems.
Craig Lawrence
