Binding depth
Jeremy D
Binding depth
Post by Jeremy D » Mon Nov 17, 2014 8:56 am
Hi guys,
I just routed the ledges on my latest build and the binding ledge is a bee's dick too tall (not the depth of the ledge but the height). I am talking about .1 mm. Do you think with swelling, gluing and scraping etc I should be able to go ahead or should I source some binding that is a little taller? I am tempted to just go for it.
Jeremy D
Re: Binding depth
Post by Bob Connor » Mon Nov 17, 2014 10:31 am
Glue some purfling to the bottom of the binding.
I'm assuming that the bindings don't already have purflings attached.
Jeremy D
Re: Binding depth
Post by Jeremy D » Mon Nov 17, 2014 10:36 am
Thanks Bob,
I thought of doing that but I have already routed past the end graft which has a thin line of maple purf on each side. I guess it wont look to bad not being mitered.
Jeremy D
Re: Binding depth
Post by Richard » Mon Nov 17, 2014 10:51 am
I too would be looking at side purfling to make up the height, though if we are talking 0.1mm, scraping/sanding of the top and back as you prepare for finishing should take care this difference no worries.
Re: Binding depth
Post by kiwigeo » Mon Nov 17, 2014 11:20 am
+1 for purflings. If that doesn't work then whack in some higher bindings. If you cant get these commercially put out a call and someone here on the forum will probably have some or be able to cut you some.
Jeremy D
Re: Binding depth
Post by Jeremy D » Mon Nov 17, 2014 12:14 pm
Thanks guys I will check out how the purf will look. What type of glue is best for gluing purfling to binding? Titebond II?
Jeremy D
Re: Binding depth
Post by Allen » Mon Nov 17, 2014 12:50 pm
0.1mm to feather the top and back into the binding would be bugger all, especially as the glue is going to swell everything up a bit. In many cases when we are giving the final voicing to the top we are taking off a bit around the lower bout anyway.
I use HHG to glue on all purflings. Never have a problem with it.
But that's my 2cents.
Re: Binding depth
Post by kiwigeo » Mon Nov 17, 2014 12:51 pm
Jeremy D wrote:Thanks guys I will check out how the purf will look. What type of glue is best for gluing purfling to binding? Titebond II?
I use Titebond III...it's a bit more resistant to heat and moisture if youre into bending your bindings before installation.
Jeremy D
Re: Binding depth
Post by Jeremy D » Mon Nov 17, 2014 1:45 pm
Thanks everyone.
Jeremy D
