Scorched Sides Advice
bdunne
Post by bdunne » Sun Apr 13, 2014 4:44 pm
Hello all,
What, I at first, thought was just a little surface scorching on some blackwood sides after bending in my machine has turned out to be virtually all the way through, The scorching is only at the waist area of both sides. I have made a decent bit of progress on this build and don't want to abandon the work so far for what seems ultimately to be an aesthetic problem.
So now I am contemplating any cosmetic means I can use to hide or blend it. Has anyone been in this territory before and found a viable fix? I am thinking of simply staining the sides black, but if someone has some experience in this area I would appreciate their input.
Many thanks
Brian
Jeremy D
Re: Scorched Sides Advice
Post by Jeremy D » Sun Apr 13, 2014 5:16 pm
Pick up some fresh sides from Tim spittle?
Jeremy D
peter.coombe
Post by peter.coombe » Sun Apr 13, 2014 5:28 pm
Take a break, then take deep breath and get some new sides and start again.
Peter
Post by Trevor Gore » Sun Apr 13, 2014 5:50 pm
If you still have plenty of structure, you could try your hand at a 'burst. You'll need to figure out if you want the extra finishing work, though!
Some pics of one here.
tippie53
Post by tippie53 » Mon Apr 14, 2014 9:23 am
what was your bending procedure?
Member of the board ASIA
bdunne
Post by bdunne » Thu Jan 08, 2015 10:11 pm
Well, it was a long time to getting finished, but I decided to "dye" the sides black to hide the scorched area but still allow the grain and figure to show through. The end result didn't turn out too bad I thought.
I'll post some more in the gallery soon, but my photographic skills are severely lacking.
Brian
Post by kiwigeo » Thu Jan 08, 2015 11:08 pm
Man that's something I would never have thought of....thinking outside the square. This has to be a serious contender for save of the year.
Post by charangohabsburg » Thu Jan 08, 2015 11:57 pm
Looks great!
It reminds me bit on those sandwich-like cookies with chocolate :D
It also reminds me on an occasion before my life as luthierie-addict when I commissioned some kind of guitarrilla to a Bolivian luthier and proposed a different wood for the sides than that of the back - because I liked how it would have looked. Unfortunately that luthier decidedly rejected the idea, saying that "things are not made that way" and that it would look bad. It was one of the first instances when I thought "oh well, I can make it like that if I find the time to make a guitar".
In any case I'm pretty sure that in a century or two this guitar will cause some serious head scratching amongst historians, which in the end will conclude that the sides were "baked" for acoustical reasons! :mrgreen:
Post by kiwigeo » Thu Jan 08, 2015 11:59 pm
Better fully baked than half baked!
Post by Trevor Gore » Fri Jan 09, 2015 12:25 pm
Excellent save, Brian.
How did you do your "dying"?
bdunne
Post by bdunne » Fri Jan 09, 2015 1:24 pm
Hi Trevor,
I used the wood dyes from u Beaut. Basically followed their recommendations. Used a mixture of the Black Green dye and the Red dye, it penetrated very well. They recommend wetting the surface a couple of times to raise the grain and sand smooth before applying the dye to minimise the amount of sanding at the end.
Brian
Post by Trevor Gore » Fri Jan 09, 2015 3:11 pm
Thanks for that, Brian. It certainly seems to have worked well. I've always fancied doing a black blackwood guitar!
Users browsing this forum: Google and 112 guests
