What to use to clearly mark dark brown wood???
Quinny
Post by Quinny » Thu Feb 12, 2015 3:24 pm
Hi,
I have been working on a uke with Walnut as the neck and Zircote for the body, but it was really hard to see pencil marks. This was a problem when cutting and filing, as I struggled to see the lines to guide my work. Made things a lot harder as it made me leave more margin in sawing, which let more sanding and filing!! I tried a light but it wasn't really helpful.
I'd be really grateful for any ideas on what to use to mark dark wood so it is more easily visible.
Andrew
Re: What to use to clearly mark dark brown wood???
Post by Allen » Thu Feb 12, 2015 3:51 pm
Get yourself a white pen from Office Works. Or a white pencil from the art supply rack.
I've got a handful of them because I simply can't see anything dark on a dark background. It's terrible getting old.
peter.coombe
Post by peter.coombe » Thu Feb 12, 2015 6:21 pm
+1 on that!
Post by 56nortondomy » Thu Feb 12, 2015 7:54 pm
I got a heap of white pencils from the reject shop, they were in packets of 3 for $2, so i bought about 6 packets, for the money they are ok, but not as good as the General charcoal white.
curly
Post by curly » Thu Feb 12, 2015 8:54 pm
For coarse writing on dark or wet timbers I use thick lyra branded artists pencils , sky blue is the pick . They can be sharpened to a reasonable point .
For marking up accurately in building I use a scribed line off a burin or knife . Rub chalk or pencil into the scribed line for the best of both , accurate and visible .
Pete
vandenboom
Post by vandenboom » Fri Feb 13, 2015 9:15 pm
Sometimes, I put a small bit of masking tape in the approx position and pencil mark that. eg. When marking out dark fingerboards, waist position when side bending, centre line on the back when the join is (hopefully) difficult to see.
Quinny
Post by Quinny » Sat Feb 14, 2015 9:46 am
Thanks guys - I could use all those ideas and will get some white pencils. Pretty obvious idea now I have heard it!!
Part of the problem was the advent of needing reading glasses, made worse with a not-so-bright shed.
Thanks again
Andrew
Post by Trevor Gore » Sat Feb 14, 2015 12:52 pm
A quiet word of warning: It is remarkable how your deleted white marking out lines can magically reappear just as you're about to buff out...
Hard Road
Post by Hard Road » Sun Feb 15, 2015 9:08 am
I use white chalk, then a normal pencil to mark over the chalk
Jim watts
Post by Jim watts » Tue Feb 17, 2015 10:38 am
Scribe a line with a knife and rub chalk into it.
Post by Nick » Tue Feb 17, 2015 10:52 am
Trevor Gore wrote:A quiet word of warning: It is remarkable how your deleted white marking out lines can magically reappear just as you're about to buff out...
You too Trevor? Those 'little' moments certainly increase your vocabulary :wink:
Post by kiwigeo » Tue Feb 17, 2015 4:09 pm
Give the wood a coat of Taubmans ceiling white......no problems then with the pencil showing up :mrgreen:
lauburu
Post by lauburu » Wed Feb 18, 2015 5:47 am
.... or pore filling
Craig Bumgarner
Post by Craig Bumgarner » Thu Feb 19, 2015 4:20 am
I use welder's chalk, which I think is actually soapstone. Sharpens and removes easily.
Craig Bumgarner
Bumgarner Guitar Blog
Users browsing this forum: Google and 103 guests
