SIX STRING UKULELE HELP
hooked
Post by hooked » Thu Mar 05, 2015 1:49 pm
Hi Group,
I am building a six string uke for a guy and not having seen one, let alone played one, I'm not sure what spacing i should set the two pair of octave strings at the nut and saddle.
I have already stuffed up once by placing the tuner holes in a slight fan formation on the headstock.....WRONG so I'm getting a little nervous about stuffing something else up.
THANKS :dru
Daryl
Re: SIX STRING UKULELE HELP
Post by Allen » Thu Mar 05, 2015 3:45 pm
Your octave or unison pairs will be from 2.0 to 2.5mm spacing at nut and saddle. Depends on the tension of the strings, their diameter and player preference etc.
hooked
Post by hooked » Thu Mar 05, 2015 4:53 pm
Wahoo....thanks Allen.
hooked
Post by hooked » Thu Mar 05, 2015 4:57 pm
This is the offending unit!
Post by Allen » Thu Mar 05, 2015 5:05 pm
Yes, you have to be careful with those tuner positions. Very easy to get it wrong and have a string riding against the post of the one closer to the nut.
Post by Nick » Fri Mar 06, 2015 5:59 am
I always do a full scale drawing of any new headstock shape or tuner configuration just to check on any clashes between string and hardware. It's a lot less destructive to use a rubber than a drill. :wink:
That top looks like it'll really pop under a coat of jam Daryl, looking forward to seeing the finished pics.
hooked
Post by hooked » Fri Mar 06, 2015 6:10 am
Yeah good call Nick. I didnt even give it a thought until a musician friend who had played my previous uke builds advised me to watch my machine head placement for the six string. As I had already shaped the headstock and drilled the holes, I had to remove the laminate, plug the holes, add material to the bottom of the headtock, reshape, redrill relaminate......whew!
I will use your suggested method next time THANKS.
Yes it will look good with finish (Tru Oil)
Daryl
Post by kiwigeo » Fri Mar 06, 2015 11:55 am
Nick wrote:I always do a full scale drawing of any new headstock shape or tuner configuration just to check on any clashes between string and hardware. It's a lot less destructive to use a rubber than a drill. :wink:
Yep that's what I do....
hooked
Post by hooked » Wed Apr 08, 2015 12:49 pm
THE FINISHED PRODUCT (Less Strings)
