NZ: Beginner hobbyist, couple of questions
Spykerwolf
Post by Spykerwolf » Mon Feb 29, 2016 2:23 pm
Hey guys. Just discovered this forum :-)
I won't call myself a Luthier, more a hobbyist since I haven't actually build my own guitar yet. I love learning about guitars though. I find it extremely interesting to experiment,restore and play guitar. I have a few questions that I hope someone can help me with.
At the moment I'm restoring a cheap classical guitar. It's worth $50 maybe, but it's been a family guitar so it has some sentimental value to me. I just have to glue the bridge on now, but I don't have a caul or clamp to do it.
Finally my questions - where does everyone source their caul/clamps from? I don't know any other luthiers (I'm in Auckland if anyone is keen to help) in my area, so relying on youtube etc to help me.
If someone from Auckland sees this, would it be possible to borrow the caul/clamp?
Thanks in advance guys, have an awesome day.
Will
Re: NZ: Beginner hobbyist, couple of questions
Post by kiwigeo » Mon Feb 29, 2016 6:13 pm
Spykerwolf wrote:Hey guys. Just discovered this forum :-)
Welcome to the forum Spykerwoolf.
Clamps for bridge glue up......I generally use long reach clamps specifically designed for bridge work. A caul for clamping up a classical bridge is usually custom made for each instrument as brace, bridge dimensions are variable. Its normal to make up a caul when the top is off the guitar but for a repair job one trick is to put a bright LED light inside the guitar and then trace brace and bridge patch (if present)layout onto a piece of paper laid over the top. From this drawing a caul can be made up. What sort of glue do you plan to use for the bridge glue up?
Spykerwolf
Post by Spykerwolf » Mon Feb 29, 2016 6:41 pm
Hi Martin thanks for the quick response :-)
Interesting, I did not know I had to custom make the caul...bummer!
At the moment I have Titebond Wood Glue, would you recommend that?
Also where did you buy the long reach clamps?
Thanks!
Will
Post by kiwigeo » Mon Feb 29, 2016 6:58 pm
Spykerwolf wrote:Hi Martin thanks for the quick response :-)
Thanks!
Titebond should do the job, Titebond I the preferred of the three variants of this glue.
The clamps I use came from Stewmac but if you're on a tight budget you may have to go for a more conventional clamp.....throat size is the critical factor. Long reach Cam clamps would be the preferred alternative but again theyre usually not a common item in a hardware store.
Spykerwolf
Post by Spykerwolf » Mon Feb 29, 2016 7:06 pm
Thanks Martin. I might just have to invest in the clamps now, and then atleast I know it's 1 less tool to get later XD
Will
Post by kiwigeo » Mon Feb 29, 2016 7:23 pm
Spykerwolf wrote:Thanks Martin. I might just have to invest in the clamps now, and then atleast I know it's 1 less tool to get later XD
If things are tight you can make your own cam clamps.....viewtopic.php?t=6812
seeaxe
Post by seeaxe » Tue Mar 01, 2016 5:55 am
Hi Will
I can help you with this. Ill pm you.
Spykerwolf
Post by Spykerwolf » Tue Mar 01, 2016 6:59 am
seeaxe wrote:Hi Will
Thanks Richard, appreciate it!
Will
Users browsing this forum: Google and 104 guests
