Trimming wood binding height
Blackstar1099
Post by Blackstar1099 » Mon Mar 21, 2016 2:23 pm
I have some jarrah that I've cut up to make some binding strips. Ive gotten the width down to 2mm on my drum sander but I can't seem to think of an easy way to true up a rough sawn edge for the height . It would take me quite a while to run them on some sandpaper on a flat surface, even then I doubt they'd be straight and square. Stewmac sell a binding trimmer that would do the job but I baulk at the price. I thought of using a feather board on my table router with a fence but I would think it might chatter and cause a mess. Any suggestions?
Re: Trimming wood binding height
Post by simso » Mon Mar 21, 2016 2:33 pm
The stewmac binding trimmer setup, is a nice piece of ingenuity and works extremely well.
Jeremy D
Post by Jeremy D » Mon Mar 21, 2016 2:45 pm
Can you lay them all up together on their side and use a hand plane on the edge (or possibly even you drum sander)?
Jeremy D
routout
Post by routout » Mon Mar 21, 2016 3:15 pm
I used a better one of these I cant find at the moment so this is a band sawed piece of wood to depth you desire and a disc made of any hard stuff with sand paper stuck to it and a bolt using the pedestal drill with the wood clamped to it and wound it up till the disc was just in contact and gently thread the binding through .I have also used the drum type in the drill with a fence next to it and slowly pulled it through . :D John.
Post by rocket » Mon Mar 21, 2016 5:42 pm
Stack them together on edge and stick them through the drum sander.
Post by Bob Connor » Mon Mar 21, 2016 7:45 pm
rocket wrote:Stack them together on edge and stick them through the drum sander.
Me too.
Tom West
Post by Tom West » Mon Mar 21, 2016 8:23 pm
3/4" MDF 3" by length of binding making sure sides are parallel. A rebate in the top face same size as rough binding. 6 or 7 screw hold downs. Trim away on table saw. The edge is backed up by the MDF and comes out clean. Hope you can follow.
Tom
Post by kiwigeo » Mon Mar 21, 2016 9:50 pm
Rout a slot in a piece of mdf so that depth matches desired height of binding. Slip the binding in the slot (use shims if its a loose fit). Run a block plane or scraper over the binding until its flush with the top of the slot. If its a bunch of strips then as above...tape them together and shove them through the drummie.
Blackstar1099
Post by Blackstar1099 » Tue Mar 22, 2016 12:11 am
Thanks for all the suggestions.
I don't have a table saw so that's won't work. I'm not sure the pieces will hold up if they're stacked side by side and put through a drum sander without support on either side but I'll try rigging something up. I like the idea of a slot in MDF and scraping or planing. I'll work something out. Or maybe I'll spring for the Stewmac trimmer. I need to order a bunch of other stuff anyway.
Thanks again.
Piero
Post by Allen » Tue Mar 22, 2016 7:14 am
When I need to do this I'll stack them together with some other scrap on either side for a bit more support, and then use some tape to wrap the bundle in several places along it's length in order to keep them perpendicular to the bed. Then pass through the drum sander.
The top of the tape is remove in the first pass, but it still tends to keep everything nice and true.
Post by Mark McLean » Wed Mar 23, 2016 9:13 am
Yep - drum sander
Post by Trevor Gore » Wed Mar 23, 2016 8:08 pm
Stack 'em on edge, hold between finger and thumb of one hand, high angle block plane in the other. It's all I've ever done. No drama at all.
dshaker
Post by dshaker » Fri Mar 25, 2016 10:57 am
Trevor Gore wrote:Stack 'em on edge, hold between finger and thumb of one hand, high angle block plane in the other. It's all I've ever done. No drama at all.
Ah, but you keep your planes sharp. :D
-Doug Shaker
Post by Trevor Gore » Sat Mar 26, 2016 11:36 am
Well, sharp is certainly important, but what really helps doing this sort of thing is a bit of candle wax on the sole of the plane. It really cuts down the friction and makes holding the stack a lot easier, because you don't need a vise-like grip to keep it steady.
Dave M
Post by Dave M » Sat Mar 26, 2016 11:29 pm
Or dry PTFE lubricant spray. It is surprising how much of the force used in planing is down to friction rather than the cutting action.
Post by Trevor Gore » Sun Mar 27, 2016 10:47 am
Dave M wrote:It is surprising how much of the force used in planing is down to friction rather than the cutting action.
Exactly.
dshaker
Post by dshaker » Thu Mar 31, 2016 5:52 am
Interesting. I don't think I have ever tried a lubricant on my plane soles. I'll give it a try! Thanks!
-Doug Shaker
Steve.Toscano
Post by Steve.Toscano » Thu Mar 31, 2016 9:54 pm
As per Trevors comment i put some candle wax on a plane sole and went at some highly figured blackwood backs. WOW!!!. Why am i only just discovering this.....
Now i need to get more candles.
routout
Post by routout » Fri Apr 01, 2016 6:13 am
I was wondering about introducing wax into the wood and then trying to put a finish over it ? :o
Jeremy D
Post by Jeremy D » Fri Apr 01, 2016 8:02 am
routout wrote:I was wondering about introducing wax into the wood and then trying to put a finish over it ? :o
The way I was tought was that you only put wax on the front part of the sole when makinging your finishing passes. That way the wax is cut away.
Jeremy D
Post by Trevor Gore » Fri Apr 01, 2016 9:21 am
felix wrote:Now i need to get more candles.
Four candles?
Post by Trevor Gore » Fri Apr 01, 2016 9:50 am
That's something I've wondered about, but in reality its never been a problem. Waxes are just long chain alkanes (oils are shorter chain alkanes). Shellite is mainly a short chain alkane "oil", methane is the shortest. So any residual wax would wipe off with Shellite. But unless you're really caking it on, the residual is likely less than the wax/oil already in the wood.
If you look at some of the old engravings of woodworkers' benches you'll see an oil pot with a bit of rag hanging out. The idea was that every now and again the sole of the plane was dragged across the rag leaving a thin film of linseed oil, which served as a lubricant and helped reduce the wear on wooden plane soles. Of course, when finishing with shellac/oil based grain fills/oil based finishes, there was never a compatibility problem. But I don't see one with epoxy based fills, for example, either.
Users browsing this forum: Google and 54 guests
