I finished the uke a couple of days ago. The main timbers came from Jeremy and were great to work with. The uke is quite loud and has a really nice tone ( I wish I knew how to play it ). The top is balsa lattice and CF braced, the back is radial braced.
Top is Huon pine
Back, sides, f/b and headplate are Gidgee
Neck is Tas oak.
Bridge is Cooba
Bindings are African blackwood
Soundport yoke is EIRW
Back headstock veneer is Tiger myrtle
Tuners are Grover
Gidgee and Huon tenor
- 56nortondomy
Re: Gidgee and Huon tenor
Hi Wayne,
That looks great! Well done!
A few questions, if I may:
1) How was the gidgee to work with (especially bending);
2) what is the finish?
3) you said "quite loud and has a really nice tone" - how do you think having no soundhole but instead a soundport has influenced this?
Thanks,
GregL.
Thanks,
GregL.
- 56nortondomy
Hi Greg and thanks for the nice comment. I found the Gidgee ok to work with, I had no trouble bending the cutaway side, I thinned it down to about 1.4mm,( I also soaked it in warm water and fabric softener ) the non cutaway was left at about 2.5mm thick and that got a small split, so I think I should have thinned it down to about 2mm. The finish is miritone gloss lacquer. I think having the lattice bracing has increased the volume, the sound really hammers out of the s/port. I'm not sure how the lack of sound hole has influenced the tone or volume, I guess it does to some degree, the lattice goes almost to the head block, that may influence it as well. Wayne
