Composed of 5 x 0.3mm layers of B&W veneers (B-W-B-W-B)
Not when you're married to a health professional like I amroutout wrote:That 's staring to look very nice ,something about a full figure is there not
The line you see at the back of the neck is paduak, the image earlier showing the neck minus fretboard reveals a CF bar each side of the truss rod 8.5 x 4 mm cross section. These bars continue straight into the headstock and back into the neck extension. They do not follow the head break angle but give some extra strength to the head/neck transition as they continue past the truss rod access slot. Hope that makes sense?blackalex1952 wrote:Is that Carbon Fibre in the neck? If so, is the CF shaped to follow the neck angle?
The carbon fibre rods run into the headstock and the ends of the rods are trimmed flush with the face of the headstock. It's usual to do it this way as it provides extra strength to the neck shaft/headstock scarf joint.Francis wrote:The line you see at the back of the neck is paduak, the image earlier showing the neck minus fretboard reveals a CF bar each side of the truss rod 8.5 x 4 mm cross section. These bars continue straight into the headstock and back into the neck extension. They do not follow the head break angle but give some extra strength to the head/neck transition as they continue past the truss rod access slot. Hope that makes sense?blackalex1952 wrote:Is that Carbon Fibre in the neck? If so, is the CF shaped to follow the neck angle?
