I have some thin superglue, pva, Selleys All Fix (multipurpose glue). The nut looks a bit munched so not sure if I should get a new one fitted.
This is an old samick Baby bass nothing flash.
Thanks but this nut will need gluing as there is no other way it will stay in place. It's an open ended slot not a fixed slot. So needs a way to secure it in place.kiwigeo wrote:I don't generally glue my nuts in as they are always a tight fit. If you do need to glue a nut then just a tiny dab of CA (super) glue is all you need.
If it was my axe I'd make up a new better fitting bone nut. Not a hard job with basic tools....
Is the nut loose even when strings are tensioned up? Is it butting up against the end of the fretboard? If glue is needed to keep the thing in place under string tension then it's not a great design. Can you put up a close up pic of the nut?mickeyj4j wrote:Thanks but this nut will need gluing as there is no other way it will stay in place. It's an open ended slot not a fixed slot. So needs a way to secure it in place.kiwigeo wrote:I don't generally glue my nuts in as they are always a tight fit. If you do need to glue a nut then just a tiny dab of CA (super) glue is all you need.
Users browsing this forum: No registered users and 210 guests
