Am getting close to finishing this big beastie and need some final info from those who know.
34" scale, 4 string ABG.
What angle is the saddle slot for general intonation across the strings?
And how much extra did you add to the scale for saddle/bridge placement?
I'm planning on using a thick saddle to accomodate any corrections required.
Cheers & Thanks
Acoustic Bass Guitar Saddle Slot & Intonation??
Re: Acoustic Bass Guitar Saddle Slot & Intonation??
I went to look at what I did for an acoustic bass, until I remembered I made a fretless bass.
Here is an online calculator that might help.
Assuming the results are close a nice thick bridge will certainly help you fine tune the intonation
http://www.liutaiomottola.com/formulae/ ... ocId165141
Peregrine Guitars
Peregrine Guitars
It sounds about the right time to build a string test rig, Craig. For a rudimentary one, all you need is a plank, a tuner, a nut, a 12th fret and an adjustable saddle. Mimic the tuner-nut and saddle-"bridge pin" (or whatever way you terminate at that end) distances so they are similar to those on the guitar.
Hi Clancy,
On a 34" scale roughly 2mm on the G and 8mm for the E will be close for most strings, the A and D may be slightly in front of a straight line between these points. The thick strings will need some help to form a bend at the saddle, once at pitch gently push down on the string in front of the saddle while holding it down behind (I use the end of a stick to hold the rear down and the side of a stick in front to avoid kinks). Similar bend forming should be done at the nut and where the string leaves the machine head.
Looking forward to the photos.
Garry.
Garry.
Thanks everyone for the replies.
This build has been dogging me for over 2 years, I'll be glad to see it go out the door!
