neck thickness/headstock thickeness
The head stock on most guitars is around 14-18mm thick, where the neck at the body join is around the 22mm or so, plus the fret board. So when making the neck, the stock would be ~22mm. How does everyone cut the scarf joint out of the one neck blank, then thickness the head stock back from the 22mm to around the 15mm for the head stock?
Matt
Matt
- Steve.Toscano
Re: neck thickness/headstock thickeness
I cut the scarf joint and then plane down the shorter surface of the headstock to thickness. Once the scarf is glued up i plane the headstock area flat.
This may help,
I did a walk through of how I cut my scarf joints for making necks, both classical and acoustic, I do each of these differently
Page 2 - half way down, I use a circular saw to size it up, bandsaw, planer, belt sander these would all work just fine
On a day when my head is not in the right space, I like to get out a hand plane and do it, something calming about rolls of swarf parting from wood that I find calming.
http://www.mirwa.com.au/HTS_Headstock_Scarf_Joint.html
I do the scarf joint and then plane top of headstock to end thickness. I leave laying out heel block end of the neck until the headstock is dressed to final thickness. My necks get tapered once heel block is glued up using a Safe-T-Planer.
Martin, you mention you taper the necks with stewmac's safety planer, is that correct.
How are you jigging this may I ask, for info I use a belt sander to shape my neck profiles.
Yes using a Wagner Safety Planer (Stewmac sells them). I place the neck on a wedge shaped holding jig with a couple of tabs that register into the truss rod slot....as per Gore and Gilet's books.simso wrote:Martin, you mention you taper the necks with stewmac's safety planer, is that correct.
Next time you do one, can you post some photos, would be pretty cool to see
- rocket
Good idea with the tabs there Martin, i use the wedge for thicknessing the neck but without the tabs you've described, think i'll make that addition!!kiwigeo wrote:Yes using a Wagner Safety Planer (Stewmac sells them). I place the neck on a wedge shaped holding jig with a couple of tabs that register into the truss rod slot....as per Gore and Gilet's books.simso wrote:Martin, you mention you taper the necks with stewmac's safety planer, is that correct.
- rocket
i also use the Safe-T-Planer to thickness/taper the peg head too..rocket wrote:Good idea with the tabs there Martin, i use the wedge for thicknessing the neck but without the tabs you've described, think i'll make that addition!!kiwigeo wrote:Yes using a Wagner Safety Planer (Stewmac sells them). I place the neck on a wedge shaped holding jig with a couple of tabs that register into the truss rod slot....as per Gore and Gilet's books.simso wrote:Martin, you mention you taper the necks with stewmac's safety planer, is that correct.
It would be good to see, always learning new stuff, have never seen a neck profiled with the safety planer.
Not having a safety planer I set up a jig to do it with a router. As with G&G I thickness the underside of the neck and the head.
It is essentially a trough with the neck supported at the shallow angle required, with the router running on the top of the trough. The bolt bar in the heel is useful here as in many other operations for fixing the neck. I use wedges to keep the neck fixed against the walls of the box. I do the same thing for the headstock but I haven't shown any pics because the clamping system with wedges and so on is not so satisfactory and I wouldn't recommend the way I currently do it.
Hope the pics show the setup.
- rocket
I like it Dave, necessity is the mother of invention, well done.
Cheers.
Rod
Cheers.
Rod
- Steve.Toscano
While we're showing off jigs. Here's my neck shaping 'jigs'.....
Repeatable, and precise neck shaping & tapering in ~10mins everytime.
I often go "manual" but when you've got a truss rod channel (I use rods in my classicals) you sometimes want to go as close as possible to the bottom of the channel but without breaking through into same. The jig and Safe-T-Planer for is a safer way of thicknessing a truss rodded neck.Steve.T wrote:While we're showing off jigs. Here's my neck shaping 'jigs'.....
Repeatable, and precise neck shaping & tapering in ~10mins everytime.![]()
Looks like a veritas spoke shave
Will do Steve,
Busy sorting out my stash of tonewood at present so benches are covered in mountains of wood. Will be back building in a few weeks time hopefully and will take some pics of the neck jig in action.
simso wrote:Next time you do one, can you post some photos, would be pretty cool to see
- Steve.Toscano
Many ways to .....kiwigeo wrote:I often go "manual" but when you've got a truss rod channel (I use rods in my classicals) you sometimes want to go as close as possible to the bottom of the channel but without breaking through into same. The jig and Safe-T-Planer for is a safer way of thicknessing a truss rodded neck.Steve.T wrote:While we're showing off jigs. Here's my neck shaping 'jigs'.....
How deep is your truss rod channel? The rods i use are 8mm (i think by memory) to go scary close to that id have to have a ~15mm thick neck inc fretboard eg incredibly thin.
My classicals are 21.5mm at their thinnest - 1st fret (leaving some ~7 - 8mm of meat left before my truss rod channel), and 24mm at the 9th fret.
I can comfortably go to 22 and 24.5 with the spoke shave just by look and feel nowadays. The rest comes off with a quick blade reset on the shave and abrasives.
Correct. Funnily enough i bought that guy on a whim. Cost me $160.simso wrote:Looks like a veritas spoke shave
The smaller stanley one pictured cost me $18 on ebay 2nd hand.
And guess which one i reach for first and use 95% of the time. Hint: its not the expensive one.
However, the veritas does have a very nice blade.
My rods requite at least a 10mm deep trench. Ill often go as close as 4mm to the trench at the headstock end of the trench....ie 14mm neck thickness (not including fretboard). I establish the neck thickness first with the safe-T-planer and once thats done I dont touch the centreline on the back of the neck with the spokeshaves during subsequent shaping.Steve.T wrote:
Many ways to .....![]()
Excellent tutorial Steve "simso"
Thanks,
I am very interested in peoples ways of shaping the back of the neck with safety planer and jig.
Currently I use a belt sander and measure as I go, but can see real merits in planing to a height and then shaping from there, good idea..
Thanks everyone ,all good food for thought.
The reason I ask i I remade the neck for the guitar I'm building (after cutting the tenon 5mm to one side on the first one!) The stock I used is around 25mm thick. When i cut the scarf joint, flipped it over and glued it, I need to thickness the head-stock down by about 10mm. If I do this on the front face of the head stock it will move the end of the fret board surface about30mm towards the body end, and will make the overall neck length too short.
Hope that makes sense! Would be ordinary to bin it and make a third neck...
If I take it off the back side of the head stock I should be right! Just how to do It? I could set up a jig and cross cut with a panel saw down to the thickness, then chisel and plane.
Matt
Matt
- Steve.Toscano
Just use a block plane and plane off the back, going across the grain down near the join. If worried about chip out at the sides when going cross just take off the corner with a chisel, make sure blade is sharp and finely set when getting close to final thickness.MattW wrote:
I had to do this in my first few builds when i kept forgetting to thickness the headstock piece pre glue up and ending up in the same situation you are in now with the body end already to size.
Make sure you check the thickness requirement for your tuners. The total thickness of the headstock, including any veneers need to be right for your tuners.MattW wrote:The head stock on most guitars is around 14-18mm thick,
For example, I have had Matons come through here where I had to put about 8 turns on the high E to get any break angle across the nut because the string posts were so high above the face.
And other Matons where the headstock was so thick that the threaded ferrules were lucky to engage by 1 turn (and some had stripped)
Great walkthrough thanks!simso wrote:This may help,
Rob Francis
As I mentioned in my reply this is the main reason I leave gluing up the heel block until Ive thicknesses the headstock. Once thats done the headstock/neck break point becomes the reference point for measuring out the rest of the neck.MattW wrote:
If you have to work the back of the headstock a block plane will do the job if you work it carefully, even better is a chisel plane. Ive got one of these from Veritas. The front of the plane unscrews and allows you to get right into tight corners with the blade.
