hey guys, thanks for chiming in.
my normal procedure is both chladni and tap tests. i don´t know what to do from them, but i still do it in the belief that stuff might coalesce in the future. anyway, this present guitar has a 0,39 g/cm3 and 5700 m/s euro spruce top and a 0,557 g/cm3 and 10 Gpa MOE mediterranenan cypress back and sides. neck is spanish cedar.
- top spectrum, unmuted back
- tap top.JPG (93.72 KiB) Viewed 63712 times
on this tap test, i guess the higher peak (at around 240 Hz) is the dipole, which shows up strongly in the chladni test from 218 til 240 Hz, but has a peak somewhere between 230-237 Hz (depending on where you lace the speaker). its always a dipole showing, albeit more clearly from 230 Hz up.
- tap spectrum, back muted
on this one, ive tried to mute the back - you can spot the 240 Hz peak (higher one) and a 218 Hz peak close to it, which i can not visualize in the chladni tests, no matter how hard i try.
The other smaller peaks (at 150 and 167 Hz) don´t even start to shake the leaves.
this top is not very heavy and was left between 2,3 (around soundhole) and 2,0 mm (between bridge and tail). bracing is not too massive either.
- sorry, only bracing image i have
thanks again,
Miguel.
