I am nearly ready to finish to start prep'ing for finish on a guitar with northern silky oak back and sides and have found despite using a flat sanding block that I have some corrugation or undulation happening. It is most prominent on the upper bout of the back where the rays are large and near the neck where I have recently been cleaning up the body join.
I assume it is from ray figure being a different hardness to the surrounding grain. I was thinking of using acqua coat and though maybe I should use this soon to harden up the softer grain so I can get a flat surface?
Any one have any tips/ideas on how to deal with this?
Corrugation/undulation in silky oak
- lamanoditrento
- rocket
Re: Corrugation/undulation in silky oak
With a nice sharp scraper, try going at 45-90 degrees across the the low areas to get it flat again the blade will only remove material from the high spots, and then a fine sand. Shouldn't try to fill it all with a filler only pore fill.
depends on what your finish is and what you will except, your finish sanding so i'm sure it'll be as smooth as.......
I'd roll with it and do a Matt Oil finish and string her up, or use a scraper and then sand out the cross grain marks and end up back to where you are now
Some guitars just don't wanna play along
people love a "bespoke" instrument anyway, call it rustic
Good luck either way, i'm sure it'll sound great
Users browsing this forum: Google and 84 guests
