Fretboard Journal #10--Summer issue...my guitar
Rick Turner
Post by Rick Turner » Thu Jun 26, 2008 11:25 am
For those who would like to see how I build acoustic guitars, the Summer issue of Fretboard Journal just came out, and it has a 16 page photo essay following the building of one guitar pretty much all the way through. I'm in there as is my assistant, Matthew Tolley. We built a 15" cutaway mini-jumbo in spectacular cocobolo with a bear claw Sitka top. This one has most of the tricks...flying buttresses, tilting neck, doubled sides, and side sound port. The photography is wonderful. I'm very grateful to Michael Simmons and Jason Verlinde of FBJ for doing this.
Rick Turner
www.renaissanceguitars.com
www.d-tar.com
Post by kiwigeo » Thu Jun 26, 2008 3:50 pm
Got my copy the other day and read the article....fascinating stuff. Dont know about the pic of you about to run your hand through the pin router though!
Rick Turner
Post by Rick Turner » Thu Jun 26, 2008 10:51 pm
I almost hate to say it, but that's one of the simpler operations I do on the pin router. You should see doing the profile outline of the bridges! I work with the pin router and a table router on that one, and the templet is double stick taped to the underside of the bridge. The pin router is spinning clockwise and the table router is spinning anti-clockwise (like you Aussies), so I can conventional cut "down grain" on the points of the bridge.
Rick Turner
www.d-tar.com
WaddyT
Post by WaddyT » Fri Jun 27, 2008 12:53 am
It is a very nice article, Rick. You are right about the photography, they did you proud on that - although, I have come to expect that of the FBJ. What a fine magazine.
Waddy
Jim Howell
Post by Jim Howell » Fri Jun 27, 2008 7:58 am
Its not often that a magazine of the quality of the Fretboard Journal comes around. I really hope that it can generate some staying power! I found the article about Rick to be very interesting with his guitars really coming from another direction. The photography brings a good perspective to how small the neck block really is. Thank you for sharing this stuff! I also have to admit that the Chris Thile interview was a facinating read as Chris and David Grisman essentially interviewed each other and I am a big fan of both of their music!
_____________
Jim Howell
Lakeland, MI USA
Post by Allen » Fri Jun 27, 2008 5:20 pm
Do any of the locals know where I can get a copy of Fret Board Journal? Tried all the larger newsagents and they don't have it. Do you have to subscribe to it in order to get a copy?
Post by kiwigeo » Fri Jun 27, 2008 9:16 pm
Allen,
If you become a subscribing member of the OLF then the magazine comes as part of the deal along with a T shirt and cup.
Cheers Martin
