Spruce/maple 1864 Torres 'inspired' classical
Strung up my latest build tonight....
Maple/spruce 1864 Torres “inspired" classical guitar, including a mini tornavoz. I really like maple.
Slightly shorter scale length - 636mm rather than the standard 650 and a 12 hole tie bridge. Bloodwood bindings, stripey blackwood bolt on neck with a truss rod.
I’m happy with the sound - as good if not better than the last one (same dimensions and bracing but rosewood/spruce). I like how these smaller classicals are turning out so the next build will be the same shape in Australian blackwood and either spruce or cedar.
- ozziebluesman
Re: Spruce/maple 1864 Torres 'inspired' classical
Very nice indeed, beautiful work.
I would like to experiment like yourself and build a few Torres style classical guitars.
Would you mind if I PM you sometime and ask a few questions about your build?
Thanks Alan, sure - happy to answer any questions.
Thanks! Yes, as is the bracewood - from Graham Hein at Kootenay Tonewoods.
A while back when I bought a bulk lot of tops I accidentally ordered a bunch of bracewood by adding 20 pounds to the order rather than 20 dollars, but the upside is I am set for great bracewood for a long while!
While it cant be seen from the outside I was pretty happy with how the internal guitar looked... its a blonde interior. Laminated maple linings, maple side braces, and spruce elsewhere.
Graham's wood is quite stiff.....I love the stuff. Torres bracing or falcate?Fisherman wrote: ↑Wed Aug 08, 2018 6:12 pmThanks! Yes, as is the bracewood - from Graham Hein at Kootenay Tonewoods.
Torres bracing. I’ve had good results with this bracing layout and the smaller body shape.
I am not a fan of epoxy - the main reason i have steered clear of CF and falcate bracing so far...
- lamanoditrento
Well done. That is is a very attractive guitar. Do you have any shots of the interior we ogle too?
- ozziebluesman
Hi Fisherman I have sent you a PM if you don't receive it would you please contact me on:
ozziebluesman@gmail.com
Hi Alan - I didnt get it so have emailed you instead.
Cheers, Peter
Cheers, Peter
Epoxy is certainly a pain to work with compared to AR or hide glue but a classical with falcate bracing is just such a different beast.
