Thanks, The main falcate braces are 10 mm at their thickest and the secondary braces are 8 mm. I used the classical top number in the equation to get the thickness. Right now I eye ball maybe more than 2 degrees but much less than 5. My saddle still needs to come down a couple of mm so I will measure the angle after I do the setup. The air and top are 80 and 170 Hz. I decided to try for a lower resonance because I had two additional bass strings. I was shooting for 180 hz but the big bridge dropped the tops resonance. The treble string sounds OK now but the guitar has K and K mini pure pickups, so if trebels ends a bit weak the player can bump up them up. The Bass notes are powerful.Dave M wrote: ↑Fri Jul 06, 2018 6:51 amAs always nice looking work John.
As always I am interested in the falcate bracing. You presumably beefed it up a bit for the extra strings so I wonder what height you ended up with? I wonder if you have had time yet to look at resonant frequencies, and perhaps particularly with this one, the bridge rotation?
I got the lower air by having a deeper guitar mostly.Jim watts wrote: ↑Sun Jul 08, 2018 3:33 amJohn,
That looks great!
How were you able to drop the main air that low? I'm primarily building with a Hauser plantilla and my air resonance is usually around 102 HZ and I would like to drop it some. Looking at Trevor's sensitivity analysis it looks like sound hole diameter and back stiffness are my knobs, was this you approach? I'd like to get to 95 Hz, maybe 90 Hz if possible.
Dave make sure you check out Greven's description as well. http://www.grevenguitars.com/retopping-demo.html the source I used for the process.
