Les Paul done and dusted!
martintaylor
Post by martintaylor » Thu Dec 13, 2018 7:48 pm
This is my version of the classic Les paul. Australian Re Cedar top (hand shaped), Mahogany body and neck, Rosewood fretboard, Maple bindings (body, neck and headstock), Ebony pickguard, and covers, Golden Age PAF pickups. I love carving the necks on my guitars and now that I am making a few carved instruments (violin, cello, archtops etc) I think I have finally worked out my "sweet spot"
GregL
Re: Les Paul done and dusted!
Post by GregL » Fri Dec 14, 2018 4:55 am
Hi Martin,
That looks gorgeous!
Is the Aust Red Cedar from Boutique timbers? From the same batch as your Les Paul Junior build (you posted in August 2018)?
Thanks,
GregL.
demonx
Post by demonx » Fri Dec 14, 2018 7:30 am
Looks great! You’d have to be very happy with that!
WJ Guitars
Post by WJ Guitars » Fri Dec 14, 2018 9:29 am
Excellent result. Much better quality than my Les Paul guitar.
martintaylor
Post by martintaylor » Fri Dec 14, 2018 6:26 pm
Hi Greg,
Yes! That slab has been very good to me so far. I have about 3-4 drop tops left with that figure. Probably not enough for a carved top but just need to work out what shape deserves it next.
H3ytm@n
Post by H3ytm@n » Mon Dec 17, 2018 1:58 pm
Very nice!!
Happy with the PUP's?
Mike
martintaylor
Post by martintaylor » Mon Jan 28, 2019 8:19 am
Hi Mike,
Yes! Now that I’ve had the chance to give it a few runs, the guitar is sounding great. I run it through a Blues Junior III Limited edition that I have replaced the speaker with a Warehouse speaker. Really broad dynamic range. I have wired it with the 1959 configuration which I might change to a modern wiring but thought I’d persevere with the older style wiring first.
Ronald_Handmade
Post by Ronald_Handmade » Fri Nov 26, 2021 11:39 am
This is stunning. I have not seen Cedar with that level of figure before. I've been thinking about timber choices for a semi-hollow Tele I'm planning, and I have several cubic meters of well-aged Australian cedar that I'm going to have to have another very close look at, I think!
Ian
Carpenter, Knifemaker, Leatherworker, and VERY amateur Luthier...
(Formerly known as Insomnomaniac)
