Glue not sticking
Glue not sticking
Post by rocket » Mon Jul 26, 2021 7:02 pm
Hi all, has anyone experienced something similar to this?
Closed the box on an archtop recently, Huon pine on Blackwood using HHG but the bloody top didn’t stick very well, on inspection with a thin blade it popped right off, glue adhered to the sides and lining ok but nearly no evidence of glue on the top! I’m thinking the natural oils in the Huon could be the problem, maybe a clean up with scraper and cleaning fluid will be the go?
Go Covid safe you all
Rod
Steve.Toscano
Re: Glue not sticking
Post by Steve.Toscano » Mon Jul 26, 2021 7:52 pm
yep the oils in huon pine can be a real problem.
When i've worked with it i cleaned the surface with acetone 10mins prior to glueing.
Post by rocket » Mon Jul 26, 2021 9:57 pm
Thanks Steve, yeah i thought as much although i've used Huon a couple of times and not had any issues with it but on those occasions i used Titebond and not the HHG i wonder if that is a contributing factor? i wouldn't have thought so.
Post by Allen » Tue Jul 27, 2021 6:10 am
I use Huon often and never had a problem. Got a soprano on the go right now so will have a close look this morning.
Post by rocket » Tue Jul 27, 2021 8:18 am
Just wondering if maybe the heat from the HHG helps draw the natural oils of the Huon to the surface? Just saying!
Rod
Post by Allen » Wed Jul 28, 2021 5:45 am
I only use HHG when gluing up the body. The soprano I'm working on had the binding channels routed yesterday and there was no problem at all.
I've heard builders saying that Huon Pine is difficult to glue, but that has never been my experience.
Post by kiwigeo » Wed Jul 28, 2021 9:19 am
Oil in the Huon as noted above. You can try wiping acetone or meths on gluing surfaces if using HHG. I've Titebond fairly good even on oily woods.
Post by rocket » Wed Jul 28, 2021 1:24 pm
Thanks everyone for your advice I have cleaned all remaining glue from relevant surfaces and wiped down with Shellite and re closed this box using Titebond this time and progressed on to routing binding channels, no sign of the top lifting off this time.
Rod
Post by kiwigeo » Wed Jul 28, 2021 2:52 pm
Great news Rod....
Steve.Toscano
Post by Steve.Toscano » Thu Jul 29, 2021 11:23 am
I'm no expert on glues, could be way off and happy to be proven wrong here.
I believe titebond original soaks a tiny amount into the surfaces of the 2 mateing pieces of wood, while protein glues (Hide glue etc) sits as a layer between the 2 surfaces.
In which case titebond will/should provide a better bond for oily timbers.
Post by rocket » Thu Jul 29, 2021 5:46 pm
Yeah,,, same build, I used Titebond on the bookmatch with no issues also, thanks Steve.
Rod
Users browsing this forum: Google and 89 guests
