New Luthier Tips du Jour video - Cutting Binding Channels
- ANZLF Approved Supplier
Here is the newest Luthier Tips du Jour video. Topic is Cutting binding channels.
As always, discussion and comments are welcome.
Enjoy!
youtu.be/
Enjoy!
youtu.be/
www.obrienguitars.com
Wish I had seen that when I was first starting out Robbie. Would have saves a lot of anxiety.
Do you bother with using a gramil to score the top before you route the channels? I haven't yet, but occasionally get some chip out that I end up having to try and camouflage, so have a gramil on order, hopping this will fix the problem
I used to always use gramil for scoring the top. Then one day I couldn't find it. How many times has that happened to us in our shops?Allen wrote:Wish I had seen that when I was first starting out Robbie. Would have saves a lot of anxiety.
- John Maddison
Re: Routing Binding channels
Hi
Is there anywhere in Australia where I can buy routing cutter bearings? If yes what range of sizes do you recommend?
Ciao
Ciao
Carbitool have a few bearings but you wont get a range of sizes like you do with the LMI/Stewmac kits.Drjay wrote:Hi
Ciao
