45deg chamfer router cutter
Post by kiwigeo » Wed Sep 19, 2012 9:09 am
Trev,
When you rout out your classical bridges you use a 45 deg chamfer cutter for the ramp aft of the saddle slot. The only cutters I can find have a guide bearing on the bottom. Could you kindly provide name of supplier of the cutters youre using.
Cheers and thanks Martin
Re: 45deg chamfer router cutter
Post by Trevor Gore » Wed Sep 19, 2012 9:25 am
Mine's a no-name cutter I got in a sale at Carbatec. It was from a boxed set that had a few bits missing that they were selling off cheap. It's one of those with the sickly green colour.
Try looking under Vee Groove Bits. Carb-i-tool do quite a wide variety from 22.5 degree through 150 degree, including, of course, a 90 degree, which looks pretty much like mine.
http://www.carbitool.com.au/
http://www.carbitool.com.au/router_catalogue.html (third row)
Post by kiwigeo » Wed Sep 19, 2012 11:26 am
In your book youre using a 45 degree cutter arent you? Cant see any 45 degree cutters in any of the links.
Post by Trevor Gore » Wed Sep 19, 2012 11:55 am
The V-groove bits are specified by their included angle, so 90 degree included angle cuts a 45 degree chamfer.
Post by kiwigeo » Wed Sep 19, 2012 12:08 pm
trevtheshed wrote:The V-groove bits are specified by their included angle, so 90 degree included angle cuts a 45 degree chamfer.
Oh right...of course :shock:
Post by kiwigeo » Wed Sep 19, 2012 1:49 pm
Ok these are the babies....item T112 on the link below. Ive used these guys for sourcing cutters many times in the past and have found their service good.
http://www.apworkshop.com.au/html_route ... b-vgb.html
J.F. Custom
Post by J.F. Custom » Wed Sep 19, 2012 6:18 pm
Martin,
They are readily available.
http://www.carbatec.com.au/815-v-grooving-bits_c18020
CMT are good quality bits.
Dekka
Post by Dekka » Wed Sep 19, 2012 9:23 pm
Worth a look is McJing Tools Online. I've bought some gear fom them (mainly because I can't afford expensive tools)
Part No: JL7729
Stuff I've bought seems pretty good and they're quick to deliver.
Post by kiwigeo » Thu Sep 20, 2012 7:46 am
J.F. Custom wrote:Martin,
Thanks Nick. The CMT cutters dont come in the size I need....3mm diam across the cutter.
Post by Trevor Gore » Thu Sep 20, 2012 9:58 am
Not sure if you're using this cutter for bridges, Martin, but the V-groove cutter I use for bridges is half inch (12.7mm) cutter diameter (1/4" shaft). The veining bit I use to reveal the string holes is 3.2mm.
Post by kiwigeo » Thu Sep 20, 2012 12:22 pm
trevtheshed wrote:Not sure if you're using this cutter for bridges, Martin, but the V-groove cutter I use for bridges is half inch (12.7mm) cutter diameter (1/4" shaft). The veining bit I use to reveal the string holes is 3.2mm.
Yes again youre right...got my cutters mixed up.
Cutters just arrived.......ordered yesterday got here the next day. Cant ask for better service than that. APworkshop come through with the goods again.
The bridge will have to wait...busy knocking up an external mold today. The next classical will be a bolt on neck affair.
