String breakage
String breakage
Hi Guys, looking for some advice.
I've got a player who is breaking a lot of strings (D and G) on his Cole Clark acoustic while playing gigs with a duo.
They are always breaking at the saddle.
I have smoothed the saddle, the break angle is not excessive.
12-53 d'Addarios both coated and plain
He thinks there is a problem with the guitar, I am inclined to think he is just playing a lot harder in the duo situation.
Any suggestions, is going to mediums worth exploring?
- Tod Gilding
Re: String breakage
Just a thought Jeff ,could it be possible that the string has cut into the soundboard and is being cut by the metal on the under saddle Transducer, er , I mean under saddle house brick.
- DSCF5505%20(Small).JPG (41.2 KiB) Viewed 12994 times
Re: String breakage
Um, wow. that's some serious gear. Is that waht they all look like inside?
Yikes
Yikes
Re: String breakage
No, just breaking on top of the saddle.
Re: String breakage
Jeff, if you've smoothed the saddle and he's still breaking the same strings then its probably him being heavy handed as you suggest. Maybe he's just not hearing himself in the duo situation and needs a better monitor. To prove that point you could try flossing the saddle in situ right in front of the guy so he can see for himself that the strings have an evenly supported run over the bridge.
- Steve.Toscano
Re: String breakage
Not the best quality strings. Maybe a combination of crappy strings and his hard playing style.jeffhigh wrote: d'Addarios
Re: String breakage
What a terrible looking pickup system!
It's certainly a head scratcher after you've smoothed the saddle, especially as it's the thicker D & G (I could understand the B or high E).
Would the guy entertain fitting a wider saddle? What I'm thinking is that the string is sitting on the contact point of the 1/8th saddle then immediately leaving the saddle so there is only that small point of contact, under 'normal' circumstances this would be acceptable. If he is a heavy hitter then the top of the saddle is effectively acting as a stress riser, almost a knife edge. A wider saddle will allow you to radius behind the break point so the string 'rolls' off the saddle increasing the contact area and spreading the load over 2-3mm of the string (ala Ervin Somogyi) and doesn't create that single stress point, it's how I've been approaching my saddles now.
Just a thought to consider.
- Kauri
Re: String breakage
Since it's the strings in the middle that are breaking, I wonder if the radius on the saddle is too small for his right hand style. Perhaps flattening the radius would help to spread the load, so to speak, over all six strings. ..or will that mean he starts breaking all six?
- Tod Gilding
Re: String breakage
nnickusa wrote:Um, wow. that's some serious gear. Is that waht they all look like inside?
Yikes
Here's The Maton Nick
- DSCF5503.JPG (48.26 KiB) Viewed 12875 times
Re: String breakage
Just as ugly, the Maton.....Can't imagine it'll add to the stability of the top in the long term....
Re: String breakage
Looks like a maton miniTod Gilding wrote:Here's The Maton Nick
Re: String breakage
There actually pretty stable, especially when you consider your bonding a 5mm lump of rosewood to the top surface, the electronics on the other hand can be very fiddly, individual little magnets with individual caps screwed up under a platennickusa wrote:Just as ugly, the Maton.....Can't imagine it'll add to the stability of the top in the long term....
Users browsing this forum: No registered users and 198 guests
