Uke heel block size
Uke heel block size
Hi all
I'm currently building a tenor uke and don't have any plans to work from, so need a bit of help. The body shape / bracing and scale length was easy enough to work out (with help), but I am unsure of the heel/head block size and design. In particular, how much wood do I leave on the body side of the kerf cuts? I was thinking about leaving 25mm - 30mm and scalloping out the centre to lighten it up, just guessing though.
Any suggestions
Col
Any suggestions
Col
Re: Uke heel block size
I should of mentioned I am using the spanish heel method, otherwise the reference to the kerf cuts may not have made sense.colburge wrote:Hi all
Any suggestions
Col
Col
Anything above 20mm should work OK - even on a tenor there's not a huge amount of string tension. 25mm sounds like a happy medium.
Chris Reed
Thanks Chris, I will run with that.ProfChris wrote:Anything above 20mm should work OK - even on a tenor there's not a huge amount of string tension. 25mm sounds like a happy medium.
Col
I use 20mm inside the body
Thanks AllenAllen wrote:I use 20mm inside the body
Col
I wouldn't scollop it though.colburge wrote:Thanks AllenAllen wrote:I use 20mm inside the body
Col
Thanks Liam, I made it around the 20mm mark, and after seeing it, I wont be scalloping it, it would be a bit light on.liam_fnq wrote:I wouldn't scollop it though.colburge wrote:Thanks AllenAllen wrote:I use 20mm inside the body
Col
Col
