F&&&&$$$$!!!
F&&&&$$$$!!!
Post by kiwigeo » Thu Apr 09, 2015 4:23 pm
Third attempt at hand bending a venetian cutaway.......just about had it nailed...then the friggin' side split in half as I was trimming the end of the side with a block plane. :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
Number four will be the one!!!!
ozwood
Re: F&&&&$$$$!!!
Post by ozwood » Thu Apr 09, 2015 5:38 pm
Sorry to hear that Mate , we have all had those moments, I have had several.
Hope the next ones the trick !
cheers,
Paul .
Re: F&&&&$$$$!!!
Post by kiwigeo » Thu Apr 09, 2015 6:03 pm
Thanks Paul,
Ill get there....time to fine tune the mold insert so the cutaway curves are less tight.
Re: F&&&&$$$$!!!
Post by rocket » Thu Apr 09, 2015 6:14 pm
Sometimes this caper can be very very trying Martin can't it!! Any chance of using a bender and heat source, say, blanket or bulbs ?
Re: F&&&&$$$$!!!
Post by kiwigeo » Thu Apr 09, 2015 6:42 pm
rocket wrote:Sometimes this caper can be very very trying Martin can't it!! Any chance of using a bender and heat source, say, blanket or bulbs ?
Yeah a bender and heat blanket would be alot easier but Im determined to do this by hand.....
Re: F&&&&$$$$!!!
Post by rocket » Thu Apr 09, 2015 7:04 pm
Fair enough, extra points for dogged determination!! I've had the hot pipe bender in the shop for quite a while but usually use the side bender for my sides, but on my current build, a Florentine, i used the hot pipe to bend the cutaway, i had a piece of wet cloth between the timber and the heat and a stainless steel strap behind to support the bend, happy with the result.
Re: F&&&&$$$$!!!
Post by kiwigeo » Sat Apr 11, 2015 5:26 pm
Persistence and perseverance pays off eventually...pity this was just a practice run.
Re: F&&&&$$$$!!!
Post by kiwigeo » Sat Apr 11, 2015 8:13 pm
I now have a nice pile of orphaned sides....looks like Ill be making a few ukes.
Steve.Toscano
Re: F&&&&$$$$!!!
Post by Steve.Toscano » Sat Apr 11, 2015 10:15 pm
What's the thickness of the sides at the cutaway?
Looks quite thick in those photos.
I work mine down to around 1.6 - 1.8mm in the cutaway area then add 2 small side braces for extra support.
Ohh and obviously soak for an hour in hot water.
Havent broken a side yet. Binding though..... :oops:
Re: F&&&&$$$$!!!
Post by kiwigeo » Sun Apr 12, 2015 9:43 am
felix wrote:What's the thickness of the sides at the cutaway?
Sides are worked down to 1.7-1.8mm around cutaway area.
Dave M
Re: F&&&&$$$$!!!
Post by Dave M » Wed Apr 15, 2015 6:11 am
Funny that. I have completely failed to achieve the cutaway bend - and I have tried! Using maple so I can't afford to let it get too hot because of scorching. Tried with some water, with a bit more, a bit less. Wrapped in Al foil since I am using spring steel...
I am using a home made bender based on the Art Abrahams machine which is based on Mike Doolin's original insight that you have to tension both bending slats to provide support around the s bend. Silicone blanket, thermocouple, dimmer switch heat control.
Still can't do it.
I have put it to one side for now to have a practice at a falcate braced classical of traditional shape. I am going to try and find a guitarmaker willing to give a couple of hours tuition.
Good luck with your continuing efforts.
Re: F&&&&$$$$!!!
Post by Nick » Wed Apr 15, 2015 1:38 pm
Maple I give the smallest amount of water, if any. Have done Florentine cutaways in figured Maple on my Archtops, IRW I give a reasonable spritz as I do with most other timbers I've bent (I've always built with a cutaway of some description) and the bend on a Maccaferri is the tightest I've done. I've always used an iron and hand bending, I just bend a little at a time (don't try to bend all in one go!) and let the timber bend at it's own rate I just supply a little tension to help it go, I hardly ever force it to bend unless it wants to be particularly awkward. Unless it's highly figured timber where it could split on the end grain figure, I've never used a slat behind the bend either to re-enforce it, fortunately to date I've never had to convert my efforts into kindling or firelighters :D So it is possible Dave, don't give up just got to be patient :wink:
Re: F&&&&$$$$!!!
Post by kiwigeo » Wed Apr 15, 2015 5:42 pm
Thanks Dave....your picture of the pile of mangled maple made me feel alot better....nothing like knowing someone else is having ten times as much trouble bending venetian cutaways as I am.
Re: F&&&&$$$$!!!
Post by Nick » Thu Apr 16, 2015 5:21 am
Whoops, I should have said Venetian cutaway not Florentine in my post :oops: I'm losing it.
