Glass scrapers
matthew
Glass scrapers
Post by matthew » Fri Oct 10, 2008 11:39 pm
Anyone else use a freshly cut piece of glass as a scraper? i just fit a DB fingerboard, then pretty much shaped and smoothed a tailpiece using nothing but a piece of broken glass.
Much nicer to use than a steel scraper; doesn't get hot, doesn't need sharpening ...
Post by Kim » Fri Oct 10, 2008 11:47 pm
Been using broken glass for years and I must agree Mathew, it does make a superb scraper. I was first introduced as a child when shaping cattle horn into ornaments such as penguins and albatross and the like. It was fun and effective and I have often carried broken glass scrapers into wood working.
I always found the thicker clear glass of old milk bottles to be best for longevity of the edge however it is true to say that a cold stubby will always get you out of a hot spot. :wink:
matthew
Post by matthew » Fri Oct 10, 2008 11:59 pm
I'd forgotten about glass ... used to use it all the time, then after having just made about 30 picture frames for my wife's current exhibition I ended up with a whole stack of glass offcuts ... I have a few 100mm wide strips of 3mm glass, and cut off a 20mm strip with a curved edge whenever I need a scraper.
Colin S
Post by Colin S » Sat Oct 11, 2008 12:15 am
Yes, have used broken glass many times as a scraper. On my lutes and historic instrument repairs I never use modern abrasives so all smoothing is done with glass scrapers.
Custom curved scrapers can also be manufactured as needed. Score the glass with a cutter then snap along the score. The opposite side to the score is the best to use.
Colin
"In 1969, I gave up alcohol and women, worst 20 minutes of my life." George Best.
Post by Allen » Sat Oct 11, 2008 7:35 pm
I read a while ago, I think it was on Frank Ford's site, about using the glass slides you get for viewing specimens on a microscope. Apparently you buy them by the box and they're cheap as chips. Just the right size for all kinds of jobs, and easy to dispose of.
Paul B
Post by Paul B » Sat Oct 11, 2008 7:51 pm
Having been a microscopist, I wouldn't think that microscope slides would be a good choice. The good ones have ground edges (hence no cutting edge), while the cheap ones are pretty thin and would be prone to breaking.
I wouldn't normally disagree with anything Frank Ford has to say, but this is the exception.
Post by Allen » Sat Oct 11, 2008 8:37 pm
I'm only really speculating that it was Frank. I can't say for certain, so I'll retract my comment and go sit in the corner. :?
matthew
Post by matthew » Sat Oct 11, 2008 11:43 pm
Well, climb outta that corner ... it could have been microscope slides, particularly if they were scored and snapped before use. But I prefer thicker window glass, less likely to snap un-intentionally while scraping.
My mum was an electron-microscopist once, and she used the edges of glass just like this to mount as blades in the microtome (a sort of tiny guillotine for shaving micron-thick slices) to prepare samples for use in the electron microscope
Post by Lillian » Sun Oct 12, 2008 3:39 am
Allen, come out of the corner. That's no place for you to be. I remember reading about them as well. And, like you, I can't recall who the advocate was, but I recall that it was someone I respected. While I was reading about it, I was thinking that backing it with a thin piece of hardwood might be a good thing. It would help prevent me from inadvertently flexing and breaking the slide.
Paul B
Post by Paul B » Sun Oct 12, 2008 9:48 am
Maybe there are some that are thicker than normal? Just 'cause I've not seen them doesn't mean much.
matthew
Post by matthew » Sun Oct 12, 2008 9:56 am
Paul B wrote:Maybe there are some that are thicker than normal?
yeah ... i think we're all here, aren't we??
:eyes
Paul B
Post by Paul B » Sun Oct 12, 2008 10:07 am
I was talking about microscope slides thanks Matt. :D
matthew
Post by matthew » Sun Oct 12, 2008 12:19 pm
oh ... i get it ... i think ... hold on, i can't work out if i'm confused or not ...
