Glass scrapers
- matthew
Glass scrapers
Anyone else use a freshly cut piece of glass as a scraper? i just fit a DB fingerboard, then pretty much shaped and smoothed a tailpiece using nothing but a piece of broken glass.
Much nicer to use than a steel scraper; doesn't get hot, doesn't need sharpening ...
Been using broken glass for years and I must agree Mathew, it does make a superb scraper. I was first introduced as a child when shaping cattle horn into ornaments such as penguins and albatross and the like. It was fun and effective and I have often carried broken glass scrapers into wood working.
I always found the thicker clear glass of old milk bottles to be best for longevity of the edge however it is true to say that a cold stubby will always get you out of a hot spot.
- matthew
I'd forgotten about glass ... used to use it all the time, then after having just made about 30 picture frames for my wife's current exhibition I ended up with a whole stack of glass offcuts ... I have a few 100mm wide strips of 3mm glass, and cut off a 20mm strip with a curved edge whenever I need a scraper.
Yes, have used broken glass many times as a scraper. On my lutes and historic instrument repairs I never use modern abrasives so all smoothing is done with glass scrapers.
Custom curved scrapers can also be manufactured as needed. Score the glass with a cutter then snap along the score. The opposite side to the score is the best to use.
Colin
Colin
"In 1969, I gave up alcohol and women, worst 20 minutes of my life." George Best.
Having been a microscopist, I wouldn't think that microscope slides would be a good choice. The good ones have ground edges (hence no cutting edge), while the cheap ones are pretty thin and would be prone to breaking.
I wouldn't normally disagree with anything Frank Ford has to say, but this is the exception.
- matthew
Well, climb outta that corner ... it could have been microscope slides, particularly if they were scored and snapped before use. But I prefer thicker window glass, less likely to snap un-intentionally while scraping.
My mum was an electron-microscopist once, and she used the edges of glass just like this to mount as blades in the microtome (a sort of tiny guillotine for shaving micron-thick slices) to prepare samples for use in the electron microscope
Allen, come out of the corner. That's no place for you to be. I remember reading about them as well. And, like you, I can't recall who the advocate was, but I recall that it was someone I respected. While I was reading about it, I was thinking that backing it with a thin piece of hardwood might be a good thing. It would help prevent me from inadvertently flexing and breaking the slide.
Users browsing this forum: No registered users and 90 guests
