Bending Irons
needsmorecowbel
Bending Irons
Post by needsmorecowbel » Tue Oct 19, 2010 8:49 pm
Has anyone made their own improvised bending iron or wood steamer? I'd prefer to not buy one and am in need of a clever shortcut.
Stu
Re: Bending Irons
Post by DarwinStrings » Tue Oct 19, 2010 8:59 pm
Re: Bending Irons
Post by rocket » Tue Oct 19, 2010 9:34 pm
Pretty high tech Jim, not everyone has access to all that fangled quipment :mrgreen: :mrgreen:
Re: Bending Irons
Post by Taffy Evans » Tue Oct 19, 2010 9:40 pm
My second attempt at this post.
Just pics this time
DSCF5122 (Small).JPG (34.63 KiB) Viewed 19451 times
DSCF5124 (Small).JPG (24.92 KiB) Viewed 19451 times
Re: Bending Irons
Post by kiwigeo » Tue Oct 19, 2010 9:59 pm
God, I wouldn't be hanging around that iron wearing my backless leather chaps...would end up with a few extra holes in the things :mrgreen:
Re: Bending Irons
Post by Lillian » Tue Oct 19, 2010 10:14 pm
Stu, if you don't want to use an open flame you can do the same thing with an industrial soldering iron or a heating element. I have an electric charcoal lighter, non-ceramic, in my project pile.
Martin, if you insist on wearing those backless chaps, you're going to get branded one of these days.
needsmorecowbel
Re: Bending Irons
Post by needsmorecowbel » Tue Oct 19, 2010 10:36 pm
This is a really cool one...http://soundsalon.com/Make_a_Bending_Iron.html
The Guy uses a barbeque ignition prong and basically takes it all apart and uses it to heat the metal pipe.
needsmorecowbel
Re: Bending Irons
Post by needsmorecowbel » Tue Oct 19, 2010 10:51 pm
Great idea Lillian i guess i could always just add a small piece of metal to put over the soldering iron in order to make sure the whole width of the timber can be bent at once. Unless i can find a fairly long industrial soldering iron. hmmmm
jjh
Re: Bending Irons
Post by jjh » Tue Oct 19, 2010 10:57 pm
I use a hot air paint stripper in a piece of 2" stainless tube
WaddyT
Re: Bending Irons
Post by WaddyT » Wed Oct 20, 2010 1:13 am
I made one with replacement truck tail pipe section, inserted an electric charcoal starter and plugged it into a router speed controller, popped in a grill thermometer, and it works great. Can't post pics yet - post count, I assume.
P1010574 (Large) (Small).JPG (35.21 KiB) Viewed 19413 times
It was a size thing. The forum doesn't accept standard sizes if the size happens to be taller than it is wide, even though the numbers are still within the parameters.
Waddy
liam_fnq
Re: Bending Irons
Post by liam_fnq » Wed Oct 20, 2010 7:01 am
Unfortunately this is one of those situations where we as Australians suffer from a serious lack of options.
I'm yet to find an electric BBQ starter and/or router control available in Aus. To run an imported 110v set up will require a pretty hefty transformer.
I use a gas burner in a pipe. I already had the burner for work so it seemed logical.
A homemade electric pipe is always an option but you'd want to know what you're doing. Electricity + metal pipe = possible ouchies.
Puff
Re: Bending Irons
Post by Puff » Wed Oct 20, 2010 9:13 am
Downunder solution - the guts of an electric hot air paint stripping gun with rheostat salvaged from a dumped fan or column heater.
If you could get your hands on one of those old bar heaters with a rheostat a little bit of sawing and rewiring would do the trick nicely.
Re: Bending Irons
Post by Lillian » Wed Oct 20, 2010 1:20 pm
What about the heating element to a stove or a toaster over? Or even an electric hot water heater. Just make sure that the element doesn't have to be submersed to work.
liam_fnq wrote: I'm yet to find an electric BBQ starter and/or router control available in Aus. To run an imported 110v set up will require a pretty hefty transformer.
Would you be able to put it on a rheostat and dial it down? And yes, Sparky is your friend with these shopmade jigs.
Re: Bending Irons
Post by Taffy Evans » Wed Oct 20, 2010 3:29 pm
The picture [above] of the iron I have used, and I have one larger, I have used since 1975, or so. Both have coiled heating elements from a room radiator and controllable oven thermostats that sets the heat where I like it. I also have safety protection on the power system too.
Martin, I didn't get my Harley until 1995, so backless chaps were not a consideration back then.
christian
Re: Bending Irons
Post by christian » Wed Oct 20, 2010 3:34 pm
Hi,
If you want a cheap and cheerful bending iron suggestion, use a high wattage clothes iron, yip a clothes iron.
make sure you take off the flimsy base cover so the steel plate is revealed, weld a piece of pipe to it, you may need a buffer piece of steel to give you clearance for tight bends. you could tap and thread the base and screw the pipe to it if you dont have access to a welder.
to fix it to your bench screw mount it to some ply or put it in your vice.
I still use the one i made 10yrs ago for my cutaway bends you can control the heat really well with the dial setting.
I spray the pipe with water to check that its at the desired heat, when it evaporates almost instantly you are good to go.
Christian
Leonardo da Vinci
www.christiandruery.com
Puff
Re: Bending Irons
Post by Puff » Wed Oct 20, 2010 5:53 pm
A rather deluxe heating element is the Watlow Firerod cartridge heater. Watlow have Ossie and NZ agents - Google.
Ronald_Handmade
Re: Bending Irons
Post by Ronald_Handmade » Thu Oct 21, 2010 12:04 am
Puff wrote:A rather deluxe heating element is the Watlow Firerod cartridge heater. Watlow have Ossie and NZ agents - Google.
http://www.watlow.com/products/heaters/ht_cart.cfm
http://www.watlow.com/contactus/saleslo ... m?region=6
Ian
Carpenter, Knifemaker, Leatherworker, and VERY amateur Luthier...
(Formerly known as Insomnomaniac)
needsmorecowbel
Re: Bending Irons
Post by needsmorecowbel » Thu Oct 21, 2010 3:44 pm
will give them a call, cheers
