Bending Irons
- needsmorecowbel
Bending Irons
Has anyone made their own improvised bending iron or wood steamer? I'd prefer to not buy one and am in need of a clever shortcut.
Stu
Stu
- rocket
Re: Bending Irons
Pretty high tech Jim, not everyone has access to all that fangled quipment
- Taffy Evans
Re: Bending Irons
My second attempt at this post.
Just pics this time
Just pics this time
- DSCF5122 (Small).JPG (34.63 KiB) Viewed 19075 times
- DSCF5124 (Small).JPG (24.92 KiB) Viewed 19075 times
Re: Bending Irons
God, I wouldn't be hanging around that iron wearing my backless leather chaps...would end up with a few extra holes in the things
Re: Bending Irons
Stu, if you don't want to use an open flame you can do the same thing with an industrial soldering iron or a heating element. I have an electric charcoal lighter, non-ceramic, in my project pile.
Martin, if you insist on wearing those backless chaps, you're going to get branded one of these days.
- needsmorecowbel
Re: Bending Irons
This is a really cool one...http://soundsalon.com/Make_a_Bending_Iron.html
The Guy uses a barbeque ignition prong and basically takes it all apart and uses it to heat the metal pipe.
- needsmorecowbel
Re: Bending Irons
Great idea Lillian i guess i could always just add a small piece of metal to put over the soldering iron in order to make sure the whole width of the timber can be bent at once. Unless i can find a fairly long industrial soldering iron. hmmmm
Re: Bending Irons
I use a hot air paint stripper in a piece of 2" stainless tube
Re: Bending Irons
I made one with replacement truck tail pipe section, inserted an electric charcoal starter and plugged it into a router speed controller, popped in a grill thermometer, and it works great. Can't post pics yet - post count, I assume.
It was a size thing. The forum doesn't accept standard sizes if the size happens to be taller than it is wide, even though the numbers are still within the parameters.Waddy
Re: Bending Irons
Unfortunately this is one of those situations where we as Australians suffer from a serious lack of options.
I'm yet to find an electric BBQ starter and/or router control available in Aus. To run an imported 110v set up will require a pretty hefty transformer.
I use a gas burner in a pipe. I already had the burner for work so it seemed logical.
A homemade electric pipe is always an option but you'd want to know what you're doing. Electricity + metal pipe = possible ouchies.
Re: Bending Irons
Downunder solution - the guts of an electric hot air paint stripping gun with rheostat salvaged from a dumped fan or column heater.
If you could get your hands on one of those old bar heaters with a rheostat a little bit of sawing and rewiring would do the trick nicely.
Re: Bending Irons
What about the heating element to a stove or a toaster over? Or even an electric hot water heater. Just make sure that the element doesn't have to be submersed to work.
Would you be able to put it on a rheostat and dial it down? And yes, Sparky is your friend with these shopmade jigs.liam_fnq wrote: I'm yet to find an electric BBQ starter and/or router control available in Aus. To run an imported 110v set up will require a pretty hefty transformer.
- Taffy Evans
Re: Bending Irons
The picture [above] of the iron I have used, and I have one larger, I have used since 1975, or so. Both have coiled heating elements from a room radiator and controllable oven thermostats that sets the heat where I like it. I also have safety protection on the power system too.
Martin, I didn't get my Harley until 1995, so backless chaps were not a consideration back then.
- christian
Re: Bending Irons
Hi,
If you want a cheap and cheerful bending iron suggestion, use a high wattage clothes iron, yip a clothes iron.
make sure you take off the flimsy base cover so the steel plate is revealed, weld a piece of pipe to it, you may need a buffer piece of steel to give you clearance for tight bends. you could tap and thread the base and screw the pipe to it if you dont have access to a welder.
to fix it to your bench screw mount it to some ply or put it in your vice.
I still use the one i made 10yrs ago for my cutaway bends you can control the heat really well with the dial setting.
I spray the pipe with water to check that its at the desired heat, when it evaporates almost instantly you are good to go.
Christian
Christian
Leonardo da Vinci
www.christiandruery.com
Leonardo da Vinci
Re: Bending Irons
A rather deluxe heating element is the Watlow Firerod cartridge heater. Watlow have Ossie and NZ agents - Google.
Re: Bending Irons
http://www.watlow.com/products/heaters/ht_cart.cfmPuff wrote:A rather deluxe heating element is the Watlow Firerod cartridge heater. Watlow have Ossie and NZ agents - Google.
http://www.watlow.com/contactus/saleslo ... m?region=6
Ian
Carpenter, Knifemaker, Leatherworker, and VERY amateur Luthier...
(Formerly known as Insomnomaniac)
- needsmorecowbel
Re: Bending Irons
will give them a call, cheers
