Ooooooooowww!! I look at her big round bottom in the background, and I get 'sooooo' excited!!!
Tis yummy Marty
Hi Rob,auscab wrote:Great pictures there Martin, Iv'e spent quite a bit of time looking at them day dreaming, did the strips on the back of the neck get glued separately ? or three at a time ?
cheers Rob
That very much depends on my patience and tolerance levels for failure. The veneering on the neck shaft took at least 3 attempts to get right. Unfortunately looking at the back of the neck and the back of the pegbox and bearing in mind my totally anal approach to building I dont really have much choice do I?Clancy wrote:Does the back of the pegbox get the stripey treatment too?
I used lime wood for the neck core and European Beech for the pegbox frame.charangohabsburg wrote:Looks great!![]()
I know this is probably not very important, but I'm just curious: which woods did you use for the neck core and pegbox frame? I think centuries ago it was quite common to use very light wood (conifers) for the neck core.
I kinda figured thet would be the casebearing in mind my totally anal approach to building I dont really have much choice do I?
Yeah no coincidence that lute and lunacy start with the same letterDarwinStrings wrote:Wow, that thing is impressive, not sure what possessed you to make it Martin, talk about "proper job nut files" minus the "files".
Botanical names ROCK!
Lucky Ive still got a sense of humour at the end of today.Clancy wrote:I knew you'd screw it up eventually![]()
Hi Tom,TKAY wrote:Thanks for the progress pics ,it is certainly inspiring a fair few to greater things.
I see the peg holes are drilled, will you be using modern tapers or the slightly narrower old
pitch?
Tom.
Users browsing this forum: Google, PeterG and 55 guests
