Lute Progress -
Re: Lute Progress - Test runs for cutting the rosette
Post by Kim » Sat Apr 09, 2011 9:41 pm
Said with my best Python French accent:
Ooooooooowww!! I look at her big round bottom in the background, and I get 'sooooo' excited!!! :wink:
Tis yummy Marty :D
duh Padma
Post by duh Padma » Sun Apr 10, 2011 2:31 am
After seeing matthews intermission pics,
me got thinking about that yer lute might look like with that rosette done up in gold leaf.
In fact, me gonna do just that, ya, a gilded up rosette, with some sort of gem stone in the center.
blessings
duh Padma
Post by kiwigeo » Sun Apr 10, 2011 6:49 pm
A bit more work on the lute today.....chiseled out the rebate in the neck for the peg head. The chisel is one of my work horses...a Robert Sorby 3/4" paring chisel.
Post by kiwigeo » Sun Apr 10, 2011 6:56 pm
The bridge with clamps off. The bridge is slighly off centre relative to the rosette but this is common on lutes. The position of the bridge is determined by the layup of the top string (chantrelle).
duh Padma
Turtle back lute questions.
Post by duh Padma » Thu May 05, 2011 4:04 am
Real gooder looking it is!
blessings
auscab
Post by auscab » Thu May 05, 2011 3:38 pm
Great pictures there Martin, Iv'e spent quite a bit of time looking at them day dreaming, did the strips on the back of the neck get glued separately ? or three at a time ?
cheers Rob
Alastair
Post by Alastair » Thu May 05, 2011 11:28 pm
noice :cl
Alastair
Post by kiwigeo » Fri May 06, 2011 10:34 am
auscab wrote:Great pictures there Martin, Iv'e spent quite a bit of time looking at them day dreaming, did the strips on the back of the neck get glued separately ? or three at a time ?
cheers Rob
Hi Rob,
Started with the middle RW strip and then worked out to each side gluing up a RW strip and purfling strip with each gluing session. A tedious task getting strips on neck matched up with the body.....twice I had to go back to square one and start again with a new neck core.
Re: Lute Progress -
Post by kiwigeo » Sat May 28, 2011 10:04 pm
More progress on the lute. Made up the pegbox frame and got the veneers done on the sides and end of same. Next step is drilling the pilot holes for the pegs and then completing the veneering.
Clancy
Re: Lute Progress -
Post by Clancy » Sun May 29, 2011 9:42 am
Does the back of the pegbox get the stripey treatment too?
Re: Lute Progress -
Post by kiwigeo » Sun May 29, 2011 10:20 am
Clancy wrote:Does the back of the pegbox get the stripey treatment too?
That very much depends on my patience and tolerance levels for failure. The veneering on the neck shaft took at least 3 attempts to get right. Unfortunately looking at the back of the neck and the back of the pegbox and bearing in mind my totally anal approach to building I dont really have much choice do I?
Re: Lute Progress -
Post by charangohabsburg » Sun May 29, 2011 10:49 am
Looks great! :cl
I know this is probably not very important, but I'm just curious: which woods did you use for the neck core and pegbox frame? I think centuries ago it was quite common to use very light wood (conifers) for the neck core.
Re: Lute Progress -
Post by kiwigeo » Sun May 29, 2011 11:34 am
charangohabsburg wrote:Looks great! :cl
I used lime wood for the neck core and European Beech for the pegbox frame.
Re: Lute Progress -
Post by Nick » Sun May 29, 2011 11:38 am
Not sure the orange tipped clamp was part of the original lutes were they? :lol:
Looking rather tasty Martin & I'm guessing we're gonna get the full stripey treatment on this peghead!
Clancy
Re: Lute Progress -
Post by Clancy » Sun May 29, 2011 12:44 pm
I kinda figured thet would be the case :P
Re: Lute Progress -
Post by kiwigeo » Tue May 31, 2011 6:16 pm
Have been doing a bit of research on how various lute makers have decorated the back of their pegboxes. I can only find one instrument where all the stripes on the neck have been carried through the back of the peghead. On some instruments the maker has carried only two or 4 of the stripes through the pegbox. What Ill probably do is carry one pair of stripes through to the pegbox. The veneer is 0.8mm thick on the pegbox of my lute so its going to be a tricky job.
Re: Lute Progress -
Post by kiwigeo » Sun Jun 05, 2011 9:41 pm
Back of the pegbox veneered. I decided to keep it simple and carry two purling strips up outer edges of pegbox back.
Re: Lute Progress -
Post by DarwinStrings » Sun Jun 05, 2011 10:28 pm
Wow, that thing is impressive, not sure what possessed you to make it Martin, talk about "proper job nut files" minus the "files".
Botanical names ROCK!
Re: Lute Progress -
Post by kiwigeo » Mon Jun 06, 2011 12:03 am
DarwinStrings wrote:Wow, that thing is impressive, not sure what possessed you to make it Martin, talk about "proper job nut files" minus the "files".
Yeah no coincidence that lute and lunacy start with the same letter
Re: Lute Progress -
Post by kiwigeo » Tue Jun 07, 2011 9:09 pm
Despite spending most of the day distracted by other matters I finally managed to get the pegbox and neck mated....another major milestone on this build. I was of two minds regarding the screw through the pegbox into the neck but ended up doing it purely as insurance.
Clancy
Re: Lute Progress -
Post by Clancy » Tue Jun 07, 2011 9:14 pm
I knew you'd screw it up eventually :lol: :lol: :lol:
Re: Lute Progress -
Post by kiwigeo » Tue Jun 07, 2011 9:18 pm
Clancy wrote:I knew you'd screw it up eventually :lol: :lol: :lol:
Lucky Ive still got a sense of humour at the end of today. :D
Re: Lute Progress -
Post by Allen » Tue Jun 07, 2011 9:51 pm
I like the way that just a couple of purfling lines continue on to the peg box. All of them would be away too much, and none would look unfinished.
TKAY
Re: Lute Progress -
Post by TKAY » Tue Jun 07, 2011 10:04 pm
Thanks for the progress pics ,it is certainly inspiring a fair few to greater things.
I see the peg holes are drilled, will you be using modern tapers or the slightly narrower old
pitch?
Tom.
Re: Lute Progress -
Post by kiwigeo » Tue Jun 07, 2011 10:12 pm
TKAY wrote:Thanks for the progress pics ,it is certainly inspiring a fair few to greater things.
pitch?
Tom.
Hi Tom,
Peg holes are plot holes only and have been rough reamed with a 1/30 taper reamer. Ill stick with this taper for the final fit of the pegs.
