October, yes October tutes
Post by simso » Mon Oct 29, 2018 9:41 pm
Wow, life’s moving fast these days.
Hope these are of interest to others.
How to Mod Podge
http://www.mirwa.com.au/HTS_Mod_Podge.html
How to make fixed Guitar Mold
http://www.mirwa.com.au/HTS_Make_Guitar_Mold_Fixed.html
How to locate Jazz Bridge
http://www.mirwa.com.au/HTS_Jazz_Bridge_Repair.html
How to Vacuum Clamp Bridges
http://www.mirwa.com.au/HTS_Vacuum_Clamp_Bridge.html
Re: October, yes October tutes
Post by Mark McLean » Tue Oct 30, 2018 6:12 am
Thanks Steve. Nice demos, as usual.
No glue squeeze-out with your vacuum clamping pictorial?
Post by lamanoditrento » Tue Oct 30, 2018 9:35 am
Had the exact same thought.
Thanks again Steve for the great tutes
Post by simso » Tue Oct 30, 2018 10:05 am
Missed that photo didn’t I, being hide glue just warm water was required at a couple of spots
Online
Post by kiwigeo » Tue Oct 30, 2018 10:52 am
Thanks Steve for more excellent tutes.
With my molds I slap on a few coats of polyurethane to make cleaning up glue and other crap off the mold a bit easier.
Post by simso » Tue Oct 30, 2018 11:22 am
Valid point, I guess becuase I am more in the repair field I predominantly dont hand onto molds, I will build a custom mold for a specific job and then at completion of job, take the hardware off and re-use it on another job, If I kept every mold I used, I would need another premises :)
Online
Post by kiwigeo » Tue Oct 30, 2018 4:06 pm
You're right about molds taking up space....
Post by Mark McLean » Tue Oct 30, 2018 10:50 pm
OK. I am glad that I am not the only one who needs to clean up glue squeeze-out!
I did a vacuum clamping of a bridge tonight, with HHG. After 12 minutes of clamping I took the vacuum off and cleaned up the glue with hot water, soft cloth and a pointy stick. It took about a minute as the squeeze-out was still "booger consistency", but the bridge was holding tight by then. This was following the method Robbie O'Brien showed us. After a quick clean-up, - clamp it again. Looks good. I hope it holds!
Post by simso » Tue Oct 30, 2018 11:18 pm
What mix ratio is your hide glue to water.
Gazm
Post by Gazm » Tue Oct 30, 2018 11:29 pm
Thanks for your informative tutes Steve.
What gram strength & clarity of HHG do you use for successful bridge glue ups?
Gaz
Post by simso » Wed Oct 31, 2018 12:31 am
I just use Behlens low strength 160gram I think it is, mixed 50/50 with water, this allows for me faster drying times and more glue in the joint. With hide glue as always, fit and finish of the joint is paramount to success.
