October, yes October tutes
Post by simso » Mon Oct 29, 2018 9:41 pm
Wow, life’s moving fast these days.
Hope these are of interest to others.
How to Mod Podge
http://www.mirwa.com.au/HTS_Mod_Podge.html
How to make fixed Guitar Mold
http://www.mirwa.com.au/HTS_Make_Guitar_Mold_Fixed.html
How to locate Jazz Bridge
http://www.mirwa.com.au/HTS_Jazz_Bridge_Repair.html
How to Vacuum Clamp Bridges
http://www.mirwa.com.au/HTS_Vacuum_Clamp_Bridge.html
Re: October, yes October tutes
Post by Mark McLean » Tue Oct 30, 2018 6:12 am
Thanks Steve. Nice demos, as usual.
No glue squeeze-out with your vacuum clamping pictorial?
Post by lamanoditrento » Tue Oct 30, 2018 9:35 am
Had the exact same thought.
Thanks again Steve for the great tutes
Post by simso » Tue Oct 30, 2018 10:05 am
Missed that photo didn’t I, being hide glue just warm water was required at a couple of spots
Post by kiwigeo » Tue Oct 30, 2018 10:52 am
Thanks Steve for more excellent tutes.
With my molds I slap on a few coats of polyurethane to make cleaning up glue and other crap off the mold a bit easier.
Post by simso » Tue Oct 30, 2018 11:22 am
Valid point, I guess becuase I am more in the repair field I predominantly dont hand onto molds, I will build a custom mold for a specific job and then at completion of job, take the hardware off and re-use it on another job, If I kept every mold I used, I would need another premises :)
Post by kiwigeo » Tue Oct 30, 2018 4:06 pm
You're right about molds taking up space....
Post by Mark McLean » Tue Oct 30, 2018 10:50 pm
OK. I am glad that I am not the only one who needs to clean up glue squeeze-out!
I did a vacuum clamping of a bridge tonight, with HHG. After 12 minutes of clamping I took the vacuum off and cleaned up the glue with hot water, soft cloth and a pointy stick. It took about a minute as the squeeze-out was still "booger consistency", but the bridge was holding tight by then. This was following the method Robbie O'Brien showed us. After a quick clean-up, - clamp it again. Looks good. I hope it holds!
Post by simso » Tue Oct 30, 2018 11:18 pm
What mix ratio is your hide glue to water.
Gazm
Post by Gazm » Tue Oct 30, 2018 11:29 pm
Thanks for your informative tutes Steve.
What gram strength & clarity of HHG do you use for successful bridge glue ups?
Gaz
Post by simso » Wed Oct 31, 2018 12:31 am
I just use Behlens low strength 160gram I think it is, mixed 50/50 with water, this allows for me faster drying times and more glue in the joint. With hide glue as always, fit and finish of the joint is paramount to success.
Users browsing this forum: No registered users and 95 guests
